NOVAROSSI Engine thread....
#2867
#2868
#2869
#2871
Having some engine issues with my new 4btt. The engine has just over a gallon through it. The issue at hand is flame outs. I had a bunch of them Saturday. Now, the only time it was flaming out was down the straight WHEN I would let off throttle. Temps are 230-255ish. Needles both about flush. I'm using the blue carb 6.5mm restricker. I'm also using the c5tgc. I did change to a new plug to see if that prevented the flame outs....no luck. Also, the temp was hot and humid yesterday...about 88 (wi). So, not sure if that could've been a issue....Any idea's?
#2872
bit tricky trying to get a tune on my toro with a good idle I have found that when I start up it idles high and about mid race the idle drops right off and it flames out due to a low idle
engine does seem a bit lean and strong down low and slightly rich up top peaking at about 3/4 length of the straight with a nova 6 plug 14t bell and 7mm insert. any suggestion to get a nice consistant idle? cheers
#2873
engine does seem a bit lean and strong down low and slightly rich up top peaking at about 3/4 length of the straight with a nova 6 plug 14t bell and 7mm insert. any suggestion to get a nice consistant idle? cheersI'm sticking to 4-5 ports.
#2874
#2875
About the fifth flameout, the toros tuning window seems narrow?
But will keep trying
Cheers
#2876
my toro seems to have a somewhat narrow window, however the biggest thing i noticed is it takes a long time to get heat in it if you're not using an engine heater. I usually have mine fired and on the track 3 minutes before the start of a qualifier, i get topped off with about 30-60sec to go and it still takes another 2mins into the race before i feel it come in. It always comes off around 235
#2877
I know it not in the league with the engines you guys are running, but any comments on tune and pipe with the lil NB21 econo engine they put out? running it in a truggy at about 800 ft above sea level (Kansas City area)
#2878
have a 086 pipe,a P-3 , a Go 2072 and a mystery pipe Thats been in my box for awhile,LMAO Was away from nitro for about 3 years. Put a few drops of after run oil in it the day before and this little bugger took about 10seconds to start.....has about a gallon of break in through it is all.
#2879
#2880
352Likes
