NOVAROSSI Engine thread....
#2116
So can I remove One of the shims under the head or will I need to buy some? Also what is the advantage of lowering the deck heighth? Thanks
#2117
#2118
Most of the current line comes in with a 0.80mm shim stack, broken down as a 0.30, 0.30, 0.20mm.
So you'll want to remove the 0.20 and replace it with a 0.10 for a total stack of 0.70
That will work well for an engine that is slightly past it's prime, running on 30% nitro, at typical elevation ranges.
As the engine ages, it loses it's compression seal and the heat of compression will be lower as well. You can gain some of the performance back by decreasing the deck height, to increase the compression ratio.
You can also cheat it by running 1-heat range hotter glowplug, but this isn't quite as reliable; but has a similar effect.
#2119
If you have any of the current generation Novarossi's you'll have to buy a pack of shims or source one accordingly.
#2122
Run the 2084 for slightly more torque; the 9853 for mega torque.
The 2096 is becoming a favorite for midsize/larger tracks as well.
If you don't want to spring the cash for a Novarossi pipeset (which I suggest you do the pipe, the JP header is actually about 99% identical to the Nova 41021); you can get a budget minded Dynamite 053 (torque) or 086 (top end) set. But the Novas are built stronger and perform better.
#2124
I have ran my Nitrotec all year with my RE10 and I have tested other pipes but really like the RE10. Its similar to the 9901 with a great bottom end and good top. I still get 12 minutes with the RE10 and it's a bottom end pipe! I am going to use it with my new BTTA also! Good Luck!
#2125
41021/9901 is a standby that universally works
#2126
The Nova Rossi 2096 pipe is an exact copy of an RB 2045, the 2045 is very linear, it depends on what header your using to get the power range your looking for, longer header, gives more bottom, short header, more top end.
#2127
So how does the RB 2087 compare to the 2096 and 9901?
Got one with an RB Fire 11 and was thinking of selling it, and running a 9901 I already have.. Under the vague assumption that the 9901 is more of an allrounder.. More after all-out power than smoothness or runtime..
#2128
#2129
http://www.extremercmods.com/pipes
#2130
i just looked those thing up, holy smokes, that thing looks crazy.. i would really like to see a review on one of them.
they are a really neat pipe , especially so if your not racing and just looking for all out wide open crazy power.....They are hand built and very sturdy.....We had quite a bit of fun testing one of these out last summer.....
I know I posted this video a 100 times already....but for HerSavage this would be the pipe he should run if all he's looking for is big power...
| + YouTube Video | |
352Likes
