Like Tree352Likes
NOVAROSSI Engine thread....
Old 06-04-2012 | 03:13 PM
  #3016
Lille-bror's Avatar
Good for you....
Lille-bror is offline
Old 06-04-2012 | 03:25 PM
  #3017
houston's Avatar
Its pretty humid here in the nw united states Bjarne
Seriously , i used to run all the fuel out of the engine and use ARO , rust all the time until i just started dumping tank after the race , no more rust
I dont leave my cars/engines in a garage or the car or in any uncontrolled atmosphere for &ny length of time though either
houston is offline
Old 06-04-2012 | 03:38 PM
  #3018
Mont, you mean stop the engine before it run out of fuel. And take out the remaining fuel in the tank. Than store the car ? Flat or upright position nose facing down (can this damage the engine front bearing seal) ? No need ARO-no more rust
Did I describe it correctly ? Thanks
Hartw is offline
Old 06-04-2012 | 03:42 PM
  #3019
Lille-bror's Avatar
Me neither. Always stores the engines inside my nice heated house. 20 years ago we never did anything with our engines and they didn't rust. I bet you are right but at the moment I don't dare to try it on my engines.
Old 06-04-2012 | 05:48 PM
  #3020
houston's Avatar
Thats a lil confusing to read but i think u got the gist of it , i think
Do not run fuel out of engine , just dump the tank , yes i store the car with front pointing down leaning against the wall , no bearing issues
houston is offline
Old 06-04-2012 | 05:56 PM
  #3021
beidle99's Avatar
been doing this since Monty told me back in March. Now I know its only been a little over 3 months, but my plus 4 looks brand new inside except for a little carbon build up on the piston, which is $$ in my book.
beidle99 is offline
Old 06-05-2012 | 10:04 AM
  #3022
Motorman007's Avatar
anyone run the New Novarossi carb?
http://www.redrc.net/2012/02/toy-fai...si/#more-51597
Motorman007 is offline
Old 06-05-2012 | 12:17 PM
  #3023
hi guys anyone know what is the rear bearing size for the bonito?
elkapitan is offline
Old 06-05-2012 | 12:33 PM
  #3024
Try looking here. http://www.novarossi.it/eng/home/index.php
Chris Reilly is offline
Old 06-05-2012 | 12:42 PM
  #3025
Yep I tried looking in there but it doesn't show the size, only part numbers though?
  #3026
houston's Avatar
14.5x26x6x6.3mm
Its an odd one
I highly recommend using the factory for replacement
houston is offline
Old 06-05-2012 | 12:57 PM
  #3027
Thanks boss, might as well order the factory bearing then
Oh one more are they the same size with the toro?
14.5x26x6x6.3mm
Its an odd one
Old 06-05-2012 | 02:45 PM
  #3028
Ross71's Avatar
Im looking at running a Toro Nero in my Serpent truggy, will the 9853 exhaust work Ok with it.
Ross71 is offline
Old 06-05-2012 | 03:32 PM
  #3029
houston's Avatar
Yep
Lmk if you need one
houston is offline
Old 06-05-2012 | 04:20 PM
  #3030
Stubbs's Avatar
Yes, it will work great.
On my Toro Nero, I switch between the 9853 (strong bottom end), and the 9901 (smoother bottom, more top end). I use the 41029 header on my Mugen because of the tight fit.
I not sure if you'll need it for the Serpent though. If you have enough room, the 41021 header is the one to get.
Stubbs is offline
