Like Tree352Likes
NOVAROSSI Engine thread....
Old 08-29-2012 | 08:22 PM
  #3766
bigjayjay1's Avatar
I've tried 2032 pipe JP awesome pipe dang thing got bent very quickly very thin it was new to very used very quickly
bigjayjay1 is offline
Old 08-29-2012 | 10:54 PM
  #3767
Lille-bror's Avatar
Originally Posted by am
Try the crono 2032 on the +4`s. you'll be amased ;-)
Sounds like fun
Would this work as well as the Crono and JP pipe?
EDIT EFRA 2032 pipe
Lille-bror is offline
Old 08-30-2012 | 04:59 AM
  #3768
Is the 29002 Button the same as the 28002 Button with an added O-ring?
dirtdemon is offline
Old 08-30-2012 | 07:23 AM
  #3769
Maximo's Avatar
9886 runs deadly on my Plus4........even with a very low clutch stall it pulls well.......Excuse the driving, Nick is not used to my Buggy or Radio....
+ YouTube Video
Maximo is offline
Old 08-31-2012 | 07:52 AM
  #3770
Guillermito's Avatar
Hello, I wonder if the pipe 9901 is equal in performance to the RB 2097? Because I would like to use this set in my Nova Bonito:
http://www.amainhobbies.com/product_...ifold-Polished
Thanks. Best Regards.
Guillermito is offline
Old 08-31-2012 | 01:47 PM
  #3771
PERROTTO's Avatar
track looks loose. imo the plus4 needs the low clutch stall to make the bottom end more usable and consistent at the lower rpms. sounds good. i would leave the clutch even on high bite tracks.
PERROTTO is offline
Old 08-31-2012 | 03:02 PM
  #3772
bigjayjay1's Avatar
Think this motor or the proto is my next purchase its a screamer. looks good for sure glad your doing more testing never bought cuase of its bottom.
Old 08-31-2012 | 03:29 PM
  #3773
Maximo's Avatar
track is super grippy....but tires and setup are little iffy ! LOL..........
Maximo is offline
Old 08-31-2012 | 03:32 PM
  #3774
Maximo's Avatar
Both Proto and Plus4 have awesome bottom end...... our track has so much bite and is so technical that it requires the engine to have piles of slow speed grunt..........Its very easy to bog a engine out on this surface, so everything is tuned to have more grunt.....very difficult to run a low stall clutch here.........
Maximo is offline
Old 09-01-2012 | 03:24 PM
  #3775
jboquire's Avatar
Default Source for Novarossi parts
Do you guys know who sells Novarossi parts here in the US?, I'm looking for 08002/10 piston and sleeve for my Plus 21-4C but I can't find it in Amain.
Thanks in advance, jb
jboquire is offline
Old 09-01-2012 | 03:28 PM
  #3776
hookem34's Avatar
R/C Tech Elite Member
Anyone run this header with a 9886 pipe? Looking to add more bottom punch to my engine without sacrificing the mid and top range performance of the pipe.
Thanks!
hookem34 is offline
Old 09-01-2012 | 03:35 PM
  #3777
http://www.absolutehobbyz.com/produc...oducts_id=2089 (if you want rod, too)
http://www.houstonsengineservice.com...products_id/78 (w/o rod)
BrakeTurnAccelerate is offline
Old 09-01-2012 | 04:49 PM
  #3778
houston's Avatar
i do
houston is offline
Old 09-01-2012 | 05:27 PM
  #3779
Originally Posted by houston
i do
+1 for Monty
1airborne
1airborne is offline
Old 09-01-2012 | 08:04 PM
  #3780
jboquire's Avatar
i do
Thanks Houston, I'll PM you.
jb
jboquire is offline
