NOVAROSSI Engine thread....
#3916
I just got a 1 gallon old serpent 811 with a nova plus 4c team factory tuned and the power is awesome but It does not idle the best as it seems to have a step down and after about 20 seconds of idling it will usually die. High speed power and low speed both are great but I am having a hard time getting a steady idle. I am use use to how the o.s. motors tune and have been told that the nova's tune completely different. Can someone point me in the right direction. Thanks.
#3918
Suspended
Sounds like your LSN is a little rich, start to lean the bottom until you have a stable idle, until that 2 stage is gone and the acceleration feels clean and doesnt bog. Do this on the starter box. Set the high speed at flush with the housing, drive the car around, go full throttle. After that full throttle run for about 1 or 2 seconds, lean it 1/8th of a turn and see if the rpm is higher. Also, lean the hsn until you get smoke up to 3/4 throttle but when you go full throttle, you dont see smoke.
Make sure you don't lean it too much though, make sure your temps dont go over 240, if you have a guage.
The OS plug will make it idle stronger and may be a little more forgiving on the tune. Its what I use and I love it, prefer it over the nova plugs.
Good luck!
#3927
And for your viewing pleasure....
#3928
#3929
Suspended
And not just me, the other engine expert guys at the track were stumped.
I have cured flameout problems, drivability issues, drastic runtime depletion issues, and tuning inconsistency issues by installing new head buttons on Novarossi engines AFTER THEY HAVE BEEN RAN WITH OS PLUGS. It destroys the taper seal. Once the engine heats up to "racing temperature" the engine does not operate to its peak potential.
It won't ruin anything as long as you don't over torque it.
And yeah, because Novarossi is like santa Claus, he knows when ur sleeping, he knows when ur awake, he knows if you've installed os plugs in your nova, right,?
Read that better, it says damaged caused by that plug, not something like a manufacturing defect.
#3930
You will always get better torque with a hotter plug because of the earlier ignition. I saw an engine that normally runs Nova plugs. Then he tried an OS plug and that also worked well. BUT!!!! When he took out the OS plug, there where small metal fragments on the thread of the plug and in the thread in the head. Why? Because the OS plug will make a new thread...
352Likes
