NOVAROSSI Engine thread....
#3167
#3170
that is in the truggy
#3171
FYI, I was planning to pick one up on a trip to Europe this year, but going through the hassle of getting reimbursed for the VAT (which, by the way, you don't get the full amount back) was going to be a hassle. Since it's limited quanitities, there was also no guarantee there would be any left by then.
I contacted the distributor, Hoeco, and found a shop that sells online. When purchasing from the US, the VAT is removed entirely. Shipping from Austria to NC was slightly more than the VAT, but not terrible. I got mine for $134 Euro, shipped.
Here's a link to the Hobby Shop in Austria MKRacing.info. (This is the English translation using Google translate). They've been really helpful, and quick to respond to e-mails.
Shoulde be a fun little motor to try out...at that price, you really can't go wrong.
thank you sir
#3173
I've been having a issue in which I'm going through glow plugs pretty fast in my nova 4btt. I'm using the c6tgc plugs. Does this mean I'm running my engine to rich? The plugs seem to have caster oil on them....dark color but, the residue comes off if I wipe it. Any thoughts guys?
On a side note- I've seen people running the 4btt 3.5 turns out HSN and 4.5 turns out on LSN....In which I cant even come close to that on LSN...4.5 turns out it lean bogs insanely. Idle is set .6mm.
#3174
And you should NOT be going through c6tgc plugs , something definitely aint right there
#3175
Needle settings vary so much depending on the climate, altitude, fuel, and all that stuff.
I notice the biggest change from humidity, temp, and especially altitude.
I say if in doubt put the top end flush and the bottom flush and start with the bottom end first, then go back and tune sparingly on the top. Don't go by turns out, it's too vague on the needles, with the exception of the idle, you have that perfect for most circumstances. The bottom usually runs a little lean when it's right, just before it runs on in the turns.
It sounds like you have the top lean and the bottom fat, and the lean top is burning it up, but that's just a guess.
If you ever have a doubt put the top flush and leave it there until you have the bottom end right and the idle.
#3176
I pretty much have the same weather conditions as Texas. Hot and humid. I'm in wis. I'm using byrons 30%. Also using the 7mm restrictor. I've been doing pinch tests on my low end. In which the rpms go upand she dies in about 5-6 secs. Not sure how good of a method that is. Though, I'm gonna try fatting the top and going out 4.5 on lsn. Yeah not sure why I'm burning up plugs!?!?!? Idea's and advice is welcomed!
. Ps- engine has over 3gallons through it. It was bench broken in by Houston and I finshed the process off with 2000cc of fuel while keeping the engine 190 210. ( sorry for the text clutter posted on my phone)
#3177
#3179
. Ps- engine has over 3gallons through it. It was bench broken in by Houston and I finshed the process off with 2000cc of fuel while keeping the engine 190 210. ( sorry for the text clutter posted on my phone)5-6 seconds on the LSN is pretty good I think for the pinch test when up to operating temp. My HSN is just out from flush on my BTT. Keep your LSN where its at for now if your getting a consistant idle and tune the HSN. It doesn't take much on these carbs to get them out of the sweet spot. Go to flush with the HSN and go from there.
#3180
352Likes
