Like Tree352Likes
NOVAROSSI Engine thread....
Old 08-28-2012 | 01:40 PM
  #3751
Maximo's Avatar
Originally Posted by Lille-bror
What a shame the 9886 isn't EFRA allowed I really loves my 086
yeah....you dont even want to know what I think about EFRA ! LOL..
thankfully over on this side of the pond we can usually run whatever we want...9886 rocks !!!!
Maximo is offline
Old 08-28-2012 | 10:09 PM
  #3752
merdith6's Avatar
Default Yep
I like my 9853ss pipes the best, but I have not tried all the pipes or anything, I just know that pipe works for me.
One thing on engines. I recently had a couple flamouts and decided to get to the bottom of it. it wasn't the engines, well one time it was too lean on the bottom haha, that was me. I had small air bubbles in the fuel line. Usually I couldn't care less if bubbles were in the line, usually not an issue, but I checked the fuel lines, no holes or tears, the tank seemed fine, no unusual leaks or anything, so I sat there and thought, hmm, what about the fuel nipple on the tank. The one on the back side closest to the engine. Hmm. I've had a few loose ones pop up over the years and bingo. It wasnt really loose, just wasnt tight, so I went to put some gasket sealer on it, nope the tube dried up solid as a, well as a solid piece of rubber. Next up the jb weld, it was still good, although the cap was welded on it, and leaked out the top of the cap. what is it with JB weld and gasket maker. I can never keep it around.
Anyway I put a very small ammount of JB weld on the threads and reinstalled the nipple and hopefully it will be sealed. Just a tip i've learned over the years. the fuel nipple takes a beating and is in a spot that is hard to see and usually is the last thing checked. it never hurts to put something on it to seal it properly. It's an easy fix. I used to always do that even on a new tank, but I guess I got lazy.
merdith6 is offline
Old 08-28-2012 | 10:22 PM
  #3753
Lille-bror's Avatar
Amen
EDIT: Have to ask: Where can I read in the ROAR and /or IFMAR pipe lists, that 9853 an 9886 are allowed for ROAR approved races?
9.2.4.2 A ROAR or IFMAR approved muffler or tuned pipe must be used in all ROAR sanctioned events.
Other than some JP pipes and some Asian pipes there is not much difference between EFRAs and IFMARs pipe lists.
EFRA approved pipe list
IFMAR approved pipe list
ROAR approved pipe list (from 2009)
Lille-bror is offline
Old 08-29-2012 | 09:01 AM
  #3754
am
Amen
Try the crono 2032 on the +4`s. you'll be amased ;-)
am is offline
Old 08-29-2012 | 10:06 AM
  #3755
houston's Avatar
I have 4 nip 2032 , they are badass !
houston is offline
Old 08-29-2012 | 10:25 AM
  #3756
maddog74's Avatar
Where are these pipes for sale looked on the web and nothing?
maddog74 is offline
Old 08-29-2012 | 10:41 AM
  #3757
jboquire's Avatar
Default 086 pipe on +4
I've been using an 053 pipe on my Plus 4 engine and it runs good but I would like to tame the bottom a bit and get more top end, is it worth trying the 086 pipe?. I run the motor on a buggy and my local track has a 200ft straightaway.
Thanks in advance, jb
jboquire is offline
Old 08-29-2012 | 11:09 AM
  #3758
run_pais's Avatar
what thinking goes into choosing a pipe based on its construction for what you want out of the engine pipe combo and where can I find detail about the construction of pipes.. If find selecting a pipe based on someone elses experience being rather subjective although I consider words from Maximo and Houston to be words of wisdom from the engine gods.lol!
run_pais is offline
Old 08-29-2012 | 12:13 PM
  #3759
houston's Avatar
i bought all i found
i keep them for special occasions
houston is offline
Old 08-29-2012 | 01:33 PM
  #3760
maddog74's Avatar
Ohhhhhh. Looks like I am on the hunt for one then.
maddog74 is offline
Old 08-29-2012 | 01:35 PM
  #3761
maddog74's Avatar
Is any EFRA 2032 pipe the same pipe as the crono 2032?
maddog74 is offline
Old 08-29-2012 | 01:44 PM
  #3762
Lille-bror's Avatar
You might get both extra bottom and top with the 86 pipe. Thats was what I gained on my old NOSRAM (Picco) engine .
Old 08-29-2012 | 02:37 PM
  #3763
houston's Avatar
the jp-2032 is goooood , i used to have the rs competitions pipe 2032 but they are brittle ya know
the 86 pipe has a nasty powerband that can become very hard to drive but makes a crapload of rpm and midrange
houston is offline
Old 08-29-2012 | 06:57 PM
  #3764
I am getting a 811T truggy and need a new motor/pipe combo for it. I have a OS Speed Hara Worlds 2 that I can transfer over from my buggy but have heard really good things about Nova motors. I know runtime is dependent on a multitude of things but I would like good runtime as well. What would you guys recommend? Thanks.
JoeC is offline
Old 08-29-2012 | 08:05 PM
  #3765
houston's Avatar
any version of the plus 4 and a 9901ss/41021 and you will be very happy
houston is offline
