Like Tree352Likes
NOVAROSSI Engine thread....
Old 08-21-2012 | 11:45 AM
  #3721
Originally Posted by Motorman007
Novarrossi P8 XLT
195.00€
195.00 EUR = 240.686 USD
http://www.top-options.fr/product_in...oducts_id=2528
Where in the USA can this motor be bought?
rcmoe is offline
Old 08-21-2012 | 11:54 AM
  #3722
beidle99's Avatar
Originally Posted by BradS
I'm confused by this nova manual, is there anything special I need to do to turn the fuel intake to point down or do I just loosen and turn it?
I believe the manual states that to spin the banjo fitting you must replace the crush washers. I have never had moved mine so I haven't needed to replace the washers.
beidle99 is offline
Old 08-21-2012 | 12:07 PM
  #3723
Motorman007's Avatar
ALSO THE PRICE CHANGED TO $163
You have to get it overseas.
I have used them in the past. Top Option and http://www.wartelle-shop.com/
Ship to the usa.
To celebrate winning the French, British and European Championships, Racing Experience along with Novarossi are offering a new engine based on the world famous P5 XLT. This P8XLT is a long stroke 8 port engine based on the well known S21 crankcase. Main features include turbo combustion chamber with O Ring, a super strong R7 conrod, a 14.5mm shaft with upsized counterweight to increase low-end torque and the 8 port sleeve with 3 exhaust ports gives quicker acceleration. To top it off there is a 60mm lightened cooling head. This motor will come in at less than EUR200 and will be available in limited quantities across the Racing Experience territories including France, UK, Portugal and the French speaking part of Belgium
I would look at some of the UK shops too.
GOT THIS
Colissimo International
shipping is 22.10 EUR = 27.5382 USD
Which is 4 days air.
163.04 EUR = 203.138 USD
230.66 USD
I may order one myself ..
Motorman007 is offline
Old 08-21-2012 | 12:30 PM
  #3724
Maxxed-out's Avatar
Just loosen, turn to where you want it and tighten.
Maxxed-out is offline
Old 08-21-2012 | 12:32 PM
  #3725
I emailed him and I will see if in the ball park for this.
Old 08-21-2012 | 01:18 PM
  #3726
Ship to the usa.
GOT THIS
230.66 USD
Thanks for the info.
rcmoe is offline
Old 08-22-2012 | 02:14 AM
  #3727
blade954's Avatar
[QUOTE=Maximo;11118134]I Would like to introduce the CRE Proto 7 .......
custom built 7 port based out of a P5 case, full ceramic bearings..............Engine is fantastic with the strongest, most useable bottom end I have seen from a .21.....Exceptional runtimes and a fantastic top end...this engine is truly badass...... We will have 10 available this week
What sort of cooling head comes with the engine.
Do you offer a steel ball engine as well....
blade954 is offline
Old 08-22-2012 | 07:52 AM
  #3728
You have PM sir.
it's are really good price!!
Old 08-22-2012 | 09:05 AM
  #3729
You have PM sir.
Sorry but I didnt get your PM
rcmoe is offline
Old 08-22-2012 | 09:23 AM
  #3730
I sent it in a email but check your pm too. ok
Old 08-22-2012 | 08:11 PM
  #3731
Maximo's Avatar
[QUOTE=blade954;11122247]
it will have the P5 head...and I could do a steel bearing version, however I do not trust the stock steel bearings on such a high RPM engine.......If you planned to change out the bearings then its all good.......
Maximo is offline
Old 08-23-2012 | 07:42 AM
  #3732
run_pais's Avatar
I found a btt crank case for real cheap. Can some one tell me if this will work with the internals from a plus 4C team engine and maybe give me a little education on the subject.
I know that the exhaust and intake ports on the sleeve will need to line up with the exhaust on the fuel slots on the crank case.
run_pais is offline
Old 08-23-2012 | 09:16 AM
  #3733
Suspended
Neal, PM'd you
rcuser567345 is offline
Old 08-23-2012 | 12:11 PM
  #3734
houston's Avatar
Yes it will work just fine , differences r minor
houston is offline
Old 08-24-2012 | 11:16 AM
  #3735
Default P5
My wrist clip came out on my p5xlt the other day and I'm sure you can figure out the rest Anyways, Im going to try to repair it and I wanted to know is the crank and PSR compatable from the older version p5 from 2006? I know someone who has an older version FS and he says it just needs a crank. I was thinking of using the psr from his engine if its compatable with mines or just using my crank in his engine if it a work. Thanks in advance.
rcmoe is offline
