Like Tree352Likes
NOVAROSSI Engine thread....
Old 06-02-2012 | 11:07 AM
  #3001
kgombe's Avatar
that sucks dude...
kgombe is offline
Old 06-02-2012 | 12:18 PM
  #3002
houston's Avatar
[QUOTE=Semple;10810342]
Originally Posted by CHOAS
For what it's worth,
I just tore down my Nitrotec that is impossible to tune, will not idle, shuts down when it's hot. flames out for no reason, etc. at 4-5 gallons. Both front and rear bearings are garbage.
Which fuel?
4-5 gallons on your nitrotec if pushed hard is good
Tip: do not run your engine out of fuel , just dump the tank
No more rusty engine that way
houston is offline
Old 06-02-2012 | 12:22 PM
  #3003
Default Bad bearings
On a new team plus 4c with break in done and 1 gallon on it rear ceramic bearing is trash and front bearing is leaking like a cive.
1airborne
1airborne is offline
Old 06-02-2012 | 12:45 PM
  #3004
houston's Avatar
1airborne
you get it from me?
houston is offline
Old 06-02-2012 | 12:46 PM
  #3005
jnorwood_losi's Avatar
1airborne
Somethings not right there.....
jnorwood_losi is offline
Old 06-02-2012 | 12:48 PM
  #3006
savannahmick's Avatar
I'm at 6 gallons of Bryrons 30/11 and mine looks great inside other than a little rust on end of crank front bearing does drool a little but it is a 17011 and thats not really a issue holds a tune and idle. I love my Nitrotec it's the reason I bought another Nova a Btta which to me is very similar but smoother with a little more top end. I do add 2% castor to the first gallon and run it thru before I race tune my Novas and after 6 gallons on the Ntec it's still is a little tough to turn over by hand and a awesome back-up for my Btta.
savannahmick is offline
Old 06-02-2012 | 01:04 PM
  #3007
[QUOTE=houston;10810769]
Originally Posted by Semple
Which fuel?
That had been with Byron 30/11. I did push it hard and I do dump the tank rather than running it out. The engine was bad for the last 2 gallons or so. Didn't want to run. It would go a 5 min qual running amazingly and then flame out as soon as the run was over. Just would not idle at all at race temp. I believe it to be the rear bearing. No rust, by the way. Same behaviour with Losi/Nova plugs, OD plugs, Nova plugs, etc.
Probably going with a 21-4c now.
Semple is offline
Old 06-02-2012 | 01:13 PM
  #3008
houston's Avatar
if any of these engines came from me , i will do what i can to help you guys out for sure
just gotta lmk
houston is offline
Old 06-03-2012 | 06:43 AM
  #3009
beidle99's Avatar
Originally Posted by houston
i was trying not to make too much light of this but many of the nova engines as of late have been coming with a subpar front bearing (compared to 17011 ) and have been causing some issues , the more of you guys that show your concern to serpent usa/desoto racing the quicker the issue will be remedied or email novarossi direct through their website
hope this helps
i try to tell my customers of this and let them choose which way to go on the front bearing
happy motorin',
Monty
Just pulled my stock btta bearing out and installed a 17011. Gotta put everything back together now. I don't think the stock bearing was going to give me any issues anytime soon, but I had some down time and wanted my plus 4 to have the bearing it was supposed to have. by the way I just checked the Nova website the other day, and the parts breakdown still shows the 17011 for the btta and 17012 for the btts.
Monty nice work on the sleeve. 2 gallons of byrons 30/11 and motor has a nice build up of oil, no rust, and carbon on the piston and button. Like Monty says just dump your tank and the end of the day and store the car with the nose pointed down and all is well
beidle99 is offline
Old 06-03-2012 | 06:52 PM
  #3010
CHOAS's Avatar
So what front bearing does the NitroTec come with and how can you tell the difference?
I had about 2-3 gallons on mine I would guess.I think a repinch and a set of bearings will buy me another 2-3 gallons its my second one this year that started acting up within about the same amount of time.Engine runs cool compared to my Orion engines.I don't think it has seen over 235 f. Super smooth,great fuel milage and plenty of power for the buggy.
If you were going to put new bearings in a Nitrotec what ones would you use?
Also running Byrons 25% / 11%. I did find very slight signs of rust/corrosion on the crank and rear bearing.I was running it out of fuel at idle after dumping the tank at the end of every race day.
CHOAS is offline
Old 06-04-2012 | 03:32 AM
  #3011
aussies1129's Avatar
thats what I always do straight after the engine comes off the track whilst its still warm with the glow starter in to burn off any fuel. the a few drops of after run through the top and carb. is this procedure still ok or is there a better way
aussies1129 is offline
Old 06-04-2012 | 05:50 AM
  #3012
Quad Racer 34's Avatar
Do you run it weekly? If so, you don't need after run oil. I use sidewinder fuel and with it you don't need to use after run oil at all. Plus after run can kill plugs. Just let it idle out after the race day like you do and you'll be good to go.
Quad Racer 34 is offline
Old 06-04-2012 | 08:18 AM
  #3013
Lille-bror's Avatar
Not in Denmark. We have to use after run oil. Guess it has something to do with humidity.
Personally I don't like taking of the air filter and plug on a dirty car. I put ARO in a 5 ml syringe with a piece of fuel line on it. Run the engine dry of fuel, and take off the fuel line on the carburator. Try to restart it with the glow driver attached until there is no more ignition. Put the syringe on the inlet nipple. With fully open throttle I press 0,75 ml ARO in the carburator. Turn the engine several seconds on the starterbox with both closed and WOT. Add 0,75 ml ARO through the carb and turn the engine on the starterbox again.
Now, you've oil all over the inside of the engine. You can store the engine for years without any problem.
Downside: After a few weeks, the AFO can get a little thicker. When you then starts the engine, it will run very lean. Solution: Turn the HSN 1 turn out and run the engine for a few minutes. Suddenly it will richen up (the ARO has been washed out from the carb) and you can turn the HSN back one turn.
Life is simple
Lille-bror is offline
Old 06-04-2012 | 11:58 AM
  #3014
houston's Avatar
Just dump the fuel out of tank and leave it , otherwise you are running all the oil that the fuel has in it out
No more rust
houston is offline
Old 06-04-2012 | 02:56 PM
  #3015
rider313's Avatar
True that Monty. I have let a engine sit for 6 months with that method and not a spot of rust.
rider313 is offline
