NOVAROSSI Engine thread....
#6466
#6467
#6468
Well I guess im going to be answering this question myself, received a clockworks modified Novarossi Virtus .21 via the DHL courier yesterday, the engine had been broken in on the bench at clockworks so I headed out to get a little more fuel through it last night in a car part, WOW comes to mind after 3 tanks of driving it, nice stable idle, tons of power everywhere, plan on getting some more fuel through it today and tomorrow so I can hit the track on sunday with it, get a race tune on it and get some video of the animal in action.
#6469
#6470
I have one coming (non clockworks) , what pipe/header are you running?
Cheers
#6471
Started out last night with the Werks 2058 & rounded Werks header which is the combo I run on my Novarossi P5 & Novarossi Bonito in the past as below.
Going to try the Werks 2058 on the Ofna double bend header tonight for a few tanks and see what I think of it before I hit the track on the weekend.
#6472
Just remember you need a longer linkage for the throttle when you install the engine with the carby moving over 8mm away from the servo with the new design crankcase, I had cut the extra length off my Xray linkage so needed to fit a new rod to make it work properly using zero servo settings
good luck with the new engine
#6473
#6474
Can anyone tell me if this is the same engine as the Novarossi Keepoff 21-4?
"This is the NovaRossi Mugen Beat Plus 21 BT4 'Keep-Off' race tuned offroad 4 port long stroke buggy engine (part #NV21BT4P). This engine is based off the Novarossi Keep-Off 21-4 which created more linear power band, higher top speed and great fuel mileage. It is finished off with the traditional Novarossi purple head with Beat graphics (Note: Engine includes Turbo Glow Plug)."
If not the exact match, anyone know the differences?
#6475
#6476
I think the cylinder is from a plus-4. It does have the lower head and machined case of the BTT though probably with exhaust squared to match the plus-4 cylinder, basically a milled down plus-4 case.
#6477
The rain won the battle on the weekend, so didn't get a chance to get more fuel through the engine or race the Clocked Novarossi Virtus .21, CRE had all ready broken the engine in for me so I got it out on the black top so as to run some more fuel through the engine before the State Title event in 10 days time, here is some footage in my Xray XT9.
| + YouTube Video | |
#6478
Are you aware of the running change recently made to the Mugen line? They were just released about a month or so back. There new name is Beat Plus 4 keep off. If this makes a differnce or not. I have the new engines in hand but not knowing what the old Beat4's were internally I can't compare changes. I will however see tomorrow if the new Beat 4 has the steped rear bearing.
352Likes
