Like Tree352Likes
NOVAROSSI Engine thread....
Old 04-12-2010 | 05:59 PM
  #496
houston's Avatar
Originally Posted by Team_Orange
Im new to the novarossi thread but have a question. I have a plus 21-4c on the way and was going to use a werks 2013 pipe. I know the novarossi pipe is better for this motor but that will have to come later. Would the 086 ofna pipe work better? Thanks in advance
The 2013 pipe works pretty well on the plus4C as does an 86 based pipe , if you use the ofna 086 be sure to use a round smooth flow header such as novarossi 41021 or the jammin round header and you will love the power !!!
houston is offline
Old 04-12-2010 | 07:06 PM
  #497
2fst2c's Avatar
So what do you think of Novarossi's suggested break in? Says when you run for the first time let it run for 30 minutes at 15-20,000 rpm. The longer the run time the better. I've always done it like most with the heat cycle method but wondered if anyone has done it like they suggest?
2fst2c is offline
Old 04-12-2010 | 07:40 PM
  #498
houston's Avatar
i really dont have any idea why they still have that break in method in the instruction manual .
keep with a heaty cycle method
houston is offline
Old 04-13-2010 | 10:04 AM
  #499
2fst2c's Avatar
I was wondering that too. I did once do it like I saw some guy had posted about and had a video about where you heat it up and run an entire gallon through it on a stand varying the rpm range and kinda heat cycling it at the same time. Got really annoying after about 30 minutes! Motor came out nice but I agree the Heat cycle method is easier. Especially with the new Competition Heat Heater!
2fst2c is offline
Old 04-13-2010 | 11:46 AM
  #500
mattozx6rr's Avatar
Questions?? When to rebuild +4
Just a quick question on rebuilding a +4
When are the suggested replacement times for the following:
bearings
rod
piston and cylinder
crank
Just kind of curious. starting to put a rebuild kit together just would like to know when it is suggested.
mattozx6rr is offline
Old 04-14-2010 | 01:50 PM
  #501
"Smiley"'s Avatar
What size are the Front/Rear Bearings in the N21R 3 Port?
"Smiley" is offline
Old 04-14-2010 | 02:11 PM
  #502
also white size of the front bearing of the plus 4
the_winner is offline
Old 04-14-2010 | 02:19 PM
  #503
Which pipe is better for the p4 team ?
Bife is offline
Old 04-14-2010 | 06:17 PM
  #504
teamlosi906's Avatar
Default fuel
hi monty what bryons fuel to run in the p5 xs houston tuned i lost the paper 30% race blend thanks
teamlosi906 is offline
Old 04-16-2010 | 12:45 PM
  #505
2fst2c's Avatar
Does the FMS have a break in shim installed from the factory? Going to run 30% and want to know if I need to re shim it after break in. Thanks.
2fst2c is offline
Old 04-16-2010 | 04:17 PM
  #506
Default ?
wats the 3005 nova pipe like compared to the 9901 and 9853?
jammin28 is offline
Old 04-16-2010 | 05:29 PM
  #507
houston's Avatar
it is already properly shimmed for 30%
houston is offline
Old 04-16-2010 | 07:04 PM
  #508
2fst2c's Avatar
Thanks Monty!
2fst2c is offline
Old 04-16-2010 | 09:16 PM
  #509
lanmine657's Avatar
had a few questions on the rossi 3 port limited, I smoked all my motors over the winter and had this one sitting in a box as a back up. What is a good pipe, what clutch setup(is it boggy with a soft setup) what restricter. My main concern is mileage not so much power, I would like to get 11min tanks. Only have a week to prepare for colorado state series so any input would be great.
lanmine657 is offline
Old 04-16-2010 | 09:24 PM
  #510
houston's Avatar
If you want a mostly mileage setup I would recommend 9901ss/41005 setup . That will be a great setup for that engine that is geared towards mileage .
houston is offline
