Like Tree352Likes
NOVAROSSI Engine thread....
Old 07-05-2011 | 11:54 AM
  #1246
houston's Avatar
Originally Posted by Stubbs
Monty,
If it's not too much trouble, would you mind expanding this list to include headers too? There's the long, short, & compact smooth headers (41020/41021/41029), but also the long, med, & short L-shaped ones as well (41005/41001/41019).
It would be great to see a kind of "mix-n-match" chart.
Thanks in advance....
holy smokes , youre killin me
i will try to put something together i suppose
although mark is the one who loves to post thirty paragraph posts
houston is offline
Old 07-09-2011 | 10:43 AM
  #1247
Default P5
Hi all. I've recently rebuilt an original P5 that I have and I've typically used a 9901 on it but was asked why am I running a bottom end pipe on an engine that has plenty of bottom which was a good question. I've ran this pipe cuz its suppose to give better run time and better suited for a buggy. Can anyone offer any insight on this and why not run a high speed pipe on this particular engine?
rcmoe is offline
Old 07-09-2011 | 03:52 PM
  #1248
Lille-bror's Avatar
Lille-bror is offline
Old 07-09-2011 | 03:54 PM
  #1249
Lille-bror's Avatar
Gentlemen.
Would a Plus 4 Team p/s fit in a normal Plus 4 (the ones with turbo head) house/bearings? Are the crank different?
Old 07-09-2011 | 04:35 PM
  #1250
R/C Lidz's Avatar
Get a second opinion, but:
-the crank is different- stroke is the same
I'd use a Team p/s in a regular plus -4. I have a regular plus-4 p/s in a +4C case
R/C Lidz is offline
Old 07-09-2011 | 04:50 PM
  #1251
Stubbs's Avatar
Hey, I made sure to say thanks......
I hear ya though, with that many possible combinations, it could get lengthy. Heck, if it's detailed enough, maybe we can get it put as a sticky so everyone will benefit.
Stubbs is offline
Old 07-10-2011 | 06:58 AM
  #1252
houston's Avatar
Originally Posted by Lille-bror
Gentlemen.
All plus 4 parts are interchangeable with the exception of the heads
houston is offline
Old 07-10-2011 | 07:33 AM
  #1253
Lille-bror's Avatar
Thanks Monty. Allways a pleasure
Old 07-10-2011 | 02:12 PM
  #1254
losi_racer's Avatar
Monty,
whats the rear bearing size for the BTT ?? i know the front is 7x19x6mm but not sure the rear. thanks
losi_racer is offline
Old 07-10-2011 | 04:20 PM
  #1255
Chad Millikan's Avatar
Originally Posted by losi_racer
Monty,
its a 14 x 25.8 x 6
Chad Millikan is offline
Old 07-10-2011 | 04:33 PM
  #1256
I just picked up a R21 nitrotec engine and have read on other threads that people are stating that it takes a couple gallons for break in to be complete???Seems odd ?
I have always used the heat cycle method, any reason for me to deviate from this method on this engine???
dan-o is offline
Old 07-10-2011 | 06:53 PM
  #1257
losi_racer's Avatar
Originally Posted by Chad Millikan
its a 14 x 25.8 x 6
thanks
Old 07-10-2011 | 08:21 PM
  #1258
I would break it in however works for you.The heat cycle method works fine.I have a little over a gallon on mine and its doing great.I'm getting 11-12 min a tank on an re10 pipe.
xxxntwv is offline
Old 07-11-2011 | 02:38 PM
  #1259
johnny t's Avatar
does anyone have a good pipe combo for a plus 28-7 in truggy? have a dynomite 053 in it now but not sure if I really like it. always struggling getting a good tune/performance on the low end with it.
johnny t is offline
Old 07-11-2011 | 03:49 PM
  #1260
your run time is based on the buggy?? or truggy??
dan-o is offline
