Like Tree352Likes
NOVAROSSI Engine thread....
Old 06-18-2011 | 07:47 PM
  #1216
merdith6's Avatar
Default Dang
I saw theJP puller on e bay, it looked pretty cool, but no need to get so aggressive. I don't understand where all this animosity is coming from, but Ive noticed it before, whatever the reason, leave me out of it.....
merdith6 is offline
Old 06-18-2011 | 07:54 PM
  #1217
houston's Avatar
Originally Posted by TommyBlazin
YEA im surprised to hear these amateur ways of removing sleeve from so-called professionals, that jp tool is second to none, i have NEVER tried anything else, as the ways mentioned can only do damage, the jp tool, you just pop it in, and pull it out, it has rubber that expands in a sense and grabs on, so when you remove your not PUSHING with a toothbrush on the bottom of a sleeve, wich happens to be the weak part, and im sure the stubborn ones, it HAS to make them slightly out of round. pm me i can direct you where to buy for under 20$...
You truly are one of a kind buddy
Btw , no zip ties here
houston is offline
Old 06-18-2011 | 07:56 PM
  #1218
TommyBlazin's Avatar
nah man, no animosity, just want to make sure the right advise is given out, for 20$ there's no worries, i have done the zip tie method, WAY BACK when i didn't know any better, its a forum, just passing the best info i can is all man....jp pullers are great, btw how much on ebay? was it the .12 or the .21 puller, id like a new one....thanks
TommyBlazin is offline
Old 06-26-2011 | 09:11 AM
  #1219
Locum51's Avatar
Questions??
Is it correct to assume the front bearing on a N21R is 7x19x6?
What's the size of the rear bearing?
Locum51 is offline
Old 06-26-2011 | 06:10 PM
  #1220
Redvet79's Avatar
Default 71012 Ceramic Front bearing
Anyone have any input on the 71012 novarossi ceramic front bearing.
I do know they aren't cheep 100.00
I did not find much info on the net.
Anyone know were to get one?
Redvet79 is offline
Old 06-26-2011 | 07:04 PM
  #1221
houston's Avatar
lmk what you want , its just that easy
houston is offline
Old 06-26-2011 | 07:05 PM
  #1222
houston's Avatar
you have to measur the backplate but most of the n21r limiteds were 14x25.8x6mm rear bearings , lmk if you need anything
houston is offline
Old 06-27-2011 | 09:11 AM
  #1223
Redvet79's Avatar
Are the nova 71012 bearings that much better than say tko?
I have a bonito that i would like to put a ceramic in the front.
Redvet79 is offline
Old 06-27-2011 | 11:53 AM
  #1224
GMS_Racing's Avatar
Anyone know where i can get the new style exhaust gasket..the ones on the BTT??
GMS_Racing is offline
Old 06-27-2011 | 05:43 PM
  #1225
houston's Avatar
i am working on it bro
the old style still work just fine on the new valley style instead of old groove/channel style fyi
houston is offline
Old 06-27-2011 | 05:45 PM
  #1226
houston's Avatar
yes they are
tko are good but the novarossi stuff is very good , its two different price points , two different quality levels
houston is offline
Old 06-28-2011 | 08:48 AM
  #1227
Grinder's Avatar
They are in stock here.
http://www.murnanmodified.com/produc...roducts_id=738
These are the most durable exhaust gaskets that I have ever seen. They are expensive, but certainly worth it.
Grinder is offline
Old 06-30-2011 | 02:38 PM
  #1228
here you go houston, now u can throw away the toothbrush...lol.. J/K relax, im trying to HELP
http://www.amainhobbies.com/product_...e-Removal-Tool
hey it got me to throw away my zip-ties, well not use anymore...the jp is cleaner, but i just ordered this, its sweet, goes to a larger size than .21 so it's more versatile..
Old 06-30-2011 | 05:24 PM
  #1229
houston's Avatar
thanks i have one , dont use it
houston is offline
Old 07-01-2011 | 04:52 AM
  #1230
bonesbs's Avatar
I know the .21 novarossi engines are mostly shimed at .80 and I've read after breakin you can take out a .10. With the .28 Plus 28-7T engine it is shimmed at .60, as once once the breakin is completed is it best to leave it shimmed at .60 or are people also taking out a .10? I'm running it in Late Model oval racing.
bonesbs is offline
