Like Tree352Likes
NOVAROSSI Engine thread....
Old 06-15-2011 | 08:56 AM
  #1201
BIGTIME's Avatar
Man I really want to try one of these 4B-TT, but the price tag is killing me. The new Ninja is even more affordable...Any fathers day specials floating around? Where are the deals?
BIGTIME is offline
Old 06-15-2011 | 09:51 AM
  #1202
I would love to try the btt too but between that n pipe ur at $500! not sure if I want the btt, x7 or Orion...decisions...decisions...
MFigueroa is offline
Old 06-15-2011 | 04:57 PM
  #1203
houston's Avatar
You know who to get a hold of
houston is offline
Old 06-18-2011 | 12:56 PM
  #1204
Lilja's Avatar
K so I have a Nova engine thats a few years old and havent been run for that long so I wanted to see if I could get it running again.
The thing is its all clogged with residual fuel and junk so I have to take it apart and clean it. Cant get the sleeve out though, its jammed so hard in there and I have nothing to pull it out with. Ive tried heating the case with a heatgun but its not helping.
Anyone have any good ideas about what to do?
Lilja is offline
Old 06-18-2011 | 01:10 PM
  #1205
chicky03's Avatar
A thick zip tie through the exhaust port, and turn the crank will usually do the trick. The sleeve will pop up and you should be able to take it out.
chicky03 is offline
Old 06-18-2011 | 01:26 PM
  #1206
Lilja's Avatar
Yea tried that it only cuts the ziptie in half.
Im beginning to suspect that it wont be possible to get this out without damaging it.
Lilja is offline
Old 06-18-2011 | 01:35 PM
  #1207
houston's Avatar
either a strong old toothbrush with the bristle end cutoff our a plastic rod to push the sleeve up from the bottom is what I use to remove all sleeves, probably a few thousand
If it is still a bit stubborn I would recommend soaking in wd-40 ,and/or heat up the block a bit
houston is offline
Old 06-18-2011 | 01:55 PM
  #1208
Lilja's Avatar
Toothbrush didnt work. Thing is the exhausthole fits almost perfectly with the hole in the sleeve so theres not really a ledge to get leverage from.
As I have already tried to heat it Im gonna try your other suggestion and let it soak in WD40 for a while.
Lilja is offline
Old 06-18-2011 | 02:11 PM
  #1209
Ambros303's Avatar
Push it up with the toothbrush from the backplate area. Use it on the bottom of the sleeve
Ambros303 is offline
Old 06-18-2011 | 02:18 PM
  #1210
merdith6's Avatar
Default well
Jp makes a sleeve puller for really cheap...
I've not tried one yet.....
merdith6 is offline
Old 06-18-2011 | 02:39 PM
  #1211
Lilja's Avatar
Yea that didnt work either it was way too stuck.
But I got it out anyway!
Fabricated a small aluminium piece from an old steeringarm from an RC18B that fitted between the intake port and the exhaust port, but not long enough to hit the case. And then I just pressed it up with the piston.
I can tell you though, it was STUCK cause I had to really use force to get it up.
Lilja is offline
Old 06-18-2011 | 02:58 PM
  #1212
hookem34's Avatar
R/C Tech Elite Member
I use a zip tie and it works perfect every time. Get a large zip tie (put piston at BDC) and run it through the exhaust port and start turning the flywheel. Should pop up enough for you pull it out with your hands.
Works lie a charm!
hookem34 is offline
Old 06-18-2011 | 03:02 PM
  #1213
Lilja's Avatar
Works lie a charm!
Yea I did that but it didnt work with this engine cause the sleeve was stuck WAY too hard so it just clipped off the ziptie.
As I said the engine has been sitting for years with fuel in it, so it was all clogged up inside.
Lilja is offline
Old 06-18-2011 | 07:33 PM
  #1214
houston's Avatar
houston is offline
Old 06-18-2011 | 07:37 PM
  #1215
TommyBlazin's Avatar
Default Forcing a delicate sleeve out with a toothbrush, NO WAY
YEA im surprised to hear these amateur ways of removing sleeve from so-called professionals, that jp tool is second to none, i have NEVER tried anything else, as the ways mentioned can only do damage, the jp tool, you just pop it in, and pull it out, it has rubber that expands in a sense and grabs on, so when you remove your not PUSHING with a toothbrush on the bottom of a sleeve, wich happens to be the weak part, and im sure the stubborn ones, it HAS to make them slightly out of round. pm me i can direct you where to buy for under 20$...
TommyBlazin is offline
