NOVAROSSI Engine thread....
#452
#454
As much clutch spring as you can find ! as in I would try a heavier spring like a 1.1 on a lighter shoe...Give the Toro a little RPM to get into power before the clutch engages....I guess you already know this stuff, I just should have been more clear on my suggestion is all...If it were me I would run a M2C 4 shoe soft on 1.05 springs using the lightened flywheel....That combo gives amazing bottom end performance without sacrificing lifespan...... I have some personal play engines that are timed extremely high that can be tricky to get bottom end from using most other clutches, but with the M2C its no issue at all.....
#456
#458
hi guys,i'll be short so i just wanna know about glow plugs for my novarossi plus 21-4 tuned edition (not the 4C) i have both button (turbo and standard) there's a standard plug in the package (rossi #5) but by now i'm not sure which button i must go..turbo or not..any advice and any advice too on wich plug for standard will be great and which one if i go turbo..i saw standard plug in two version..short and long body it's gonna be only for racing no bashing at all in a temperature around 20/25 degres celcius (canada) thx for your comments and your help need to know soon cuz i'm about to push enter on Amain!
#460
The toro will still be made. They just came out with a team version for 2010. So I would be suprised. It is a popular engine. I ran one in a buggy and it was really nice. Plenty of everything....
#461
#462
#463
the 3 port is a great engine for buggy, I ran one once in a truck and it left me asking for more(however you may be able to clutch it and pipe it to be good)that does'nt say a whole lot as my trigger finger is very LIGHT, that's why I prefer the plus4 with a 9901/41021......it's butter smooth with GOBS of USABLE power everywhere throughout the powerband........I am running a plus4 paired with a 9853/41005 in my truck this season..............good luck with your new Novarossi.
I think most will tell you either 21-4, p5x or 21-7 for Arena Truck.
#464
#465
352Likes
