Like Tree352Likes
NOVAROSSI Engine thread....
Old 01-27-2010 | 09:26 PM
  #301
PowerHouse's Avatar
I always thought the 367 was a great engine. A lot of guys complained that they were flame out kings but the few guys I modded them for locally never had any trouble. We had similar success with the Plus21-5 as people complained of that one as well. For $225, it is definately worth a look. Where are they on sale for that price?
PowerHouse is offline
Old 01-27-2010 | 09:41 PM
  #302
Frank L's Avatar
Originally Posted by Michael#81
Get with Mark @ Powerhouse. I know he has them in stock.
Yep Mark has them.
Frank L is offline
Old 01-27-2010 | 09:56 PM
  #303
http://www.houstonsengineservice.com...69343c962a7120
RAlmeida is offline
Old 01-27-2010 | 10:15 PM
  #304
merdith6's Avatar
Default they do flame out
It's a fast engine, but mine was tough to tune....jmo...
I noticed my p5 had two allu. shims and one thin brass shim, is it ok to take out the thin brass one. What shims do yall use in a p5...
merdith6 is offline
Old 01-27-2010 | 11:32 PM
  #305
PowerHouse's Avatar
I have always pulled the .1 shim out of P5 head. Just be aware that if you run hotter plugs, you run a higher risk of preignition. Run a medium or cold plug if you want to be safe. If you elect to run a hot plug, your tune better be spot on. You can always run lower nitro %'s if you want but I assume you want to stick with your current fuel.
Old 01-28-2010 | 02:08 AM
  #306
a little help guys...
Well after 9 tanks on parking lot as i said before a week. 21/1/10 At sunday i race at the first Truggy Master for 2010 here in Greece... With my new engine of course,the Plus 4... I race it with the same ''set up'' as i broke in... Byron 25% with 11% oil, Novarossi C6TGC glow plug,stock shimming , dynamite 053 pipe and 41021 novarossi header and 6.5 venturi...Tha race day was at 5 Celcious , i tune also my plus4 and never NEVER flameout ...My idle gap is so little,tiny idle gap.. My LSN is a little in from flush and my HSN is not tune at the race set up.... at the Qualify i get from the engine 80-86 Celcius and at the race 92 C... when i broke in my engine i get 95-105 with wrap head.... Also i never get over 8 minutes... my pitman said that when i go for refuelling i had some drops of fuel in the tank and i went for refuelling after 7.30 minutes..
Why so little run time?
I have so little run time because the engine have run only aprox. 1800ml-2000ml of fuel? rich set up?
Very good engine no flameouts if you tune it properly ver stable ,very powerfull even for a truggy but i want more run times
also i found my piston and the bottom of the button black-gold-brown but more to black ....This mean rich set up?
the_winner is offline
Old 01-28-2010 | 02:24 AM
  #307
Nitro Norway's Avatar
Get a 9901pipeI hve had the same problem with my toro nero, and you will smooth out the power band with the 9901/41029.And you can use odonnell97t glow plug then you will be doing 9-9.5min runs.Absolutly love this combo
Nitro Norway is offline
Old 01-28-2010 | 03:54 AM
  #308
I lost the grub screw on my 9901 SS. Does anyone know what size the screw is or have a link to a seller.
Thanks roy
Inertia is offline
Old 01-28-2010 | 08:09 AM
  #309
Torian4000's Avatar
Anybody try the 3005, or 3004 yet?
Torian4000 is offline
Old 01-28-2010 | 12:18 PM
  #310
PowerHouse's Avatar
I was just reading that post and that was my first thought I was like either he has that thing too rich or that pipe and header are not responding as well as it could to that engine. There could be other reasons but unless I am seeing things for myself, it is always difficult to diagnose things over the net. If it was me, I would try another tuned section (9901SS or 9886) with the same header and see what you get.
Old 01-28-2010 | 12:25 PM
  #311
My engine is still new it has burn aprox 2L of fuel...I have read that need over a gallon to see better run times... But i get the same run times as my dynamite 28 with 7.5 venturi and the nova is 21 with 6.5 venturi... But it is still rich in the HSN and it has medium plug in a very cold weather... For cold weather C5TGC or C5TGF?
Old 01-28-2010 | 12:27 PM
  #312
vladconnery's Avatar
I would switch to an odonnel plug 99T. Nova engines are excellent, Nova plugs however are not.
vladconnery is offline
Old 01-28-2010 | 12:57 PM
  #313
This is the reason that i have small run times?i must change and the button head if i put OD plug?
Old 01-28-2010 | 03:28 PM
  #314
hambone's Avatar
The 3000 series pipes are made to be quiet for european efra rules. They sacrifice power for quieter operation.
hambone is offline
Old 01-28-2010 | 04:33 PM
  #315
Thanks roy
Does anyone know this?
Inertia is offline
