Like Tree352Likes
NOVAROSSI Engine thread....
Old 07-25-2010 | 12:15 AM
  #601
merdith6's Avatar
Default Cool
Originally Posted by jet flyer
One question. What after run oil is safe for the silicone ramp on the crank?
I use Marvel Mystery oil, but I'm not sure it's safe on the filled crank.....
Monty recommended me to RB mods oil and I have been using it for a few weeks on a HES P5 motor seams good[/QUOTE]
Thanks man....
merdith6 is offline
Old 07-25-2010 | 10:45 AM
  #602
Lille-bror's Avatar
Originally Posted by aussies1129
yes that sounds like the problem i am having with 25% I will try the 77t and retune
thanks
Good luck
Still, you can have flame outs after refueling. Don't never fill fuel in the neck of the tank. When the lid closes, you'll have too much pressure in the tubes and the engine will run too rich. Mount an fuel filter (without the filter insert) as close as possible to the tank in the pressure tube from the exhaust.
M7H taught me that:
http://www.rctech.net/forum/nitro-of...ml#post6066317
Lille-bror is offline
Old 07-25-2010 | 06:03 PM
  #603
UniqueAustin's Avatar
Default p5xlt
What is the best pipe for fuel. I'm switching from go and looking for long run times and smoth power transition.
UniqueAustin is offline
Old 07-25-2010 | 09:54 PM
  #604
houston's Avatar
Buggy or truggy ?
9901ss/41005 buggy
2084ss/41021 truggy
Works on most novarossi engines , 9886/41021 is another AWESOME buggy pipe combo that can even be used on truggy
houston is offline
Old 07-25-2010 | 10:06 PM
  #605
Originally Posted by houston
Buggy or truggy ?
9901ss/41005 buggy
2084ss/41021 truggy
Main buggy but looking at running this in both. Do I need the special header to run in Mugen
Old 07-27-2010 | 08:26 PM
  #606
might be getting a bf3 port and I was wondering will a 9901 pipe kill this motor or make it a pretty good runner? I know a lot of people run the 9886 but I would like to know if the 9901 will do the trick?
NitroLuver is offline
Old 07-28-2010 | 09:17 PM
  #607
JANKEII's Avatar
I wish the 9886 was a ss pipe. Would buy more. To fragile for the price...
Buggy or truggy ?
9901ss/41005 buggy
2084ss/41021 truggy
JANKEII is offline
Old 07-29-2010 | 03:44 AM
  #608
BLKNOTCH's Avatar
Yes, 41030 (long) 41029 (short)
BLKNOTCH is offline
Old 07-29-2010 | 07:09 AM
  #609
Anyone running those "Stacker" venturi's from Innovative Designs? Just curious as to the performance vs. a standard venturi. They are about 2x the price, so wondering if they are a waste of money compared to the $7 Nova inserts? BTW, I run a modded N21BF with Dynamite 086 pipe on primarily small tracks.
sdtech58 is offline
Old 07-30-2010 | 04:17 AM
  #610
In the market for a new motor and have been looking at a S21P5XLT,,,,read that this motor can use standard and or turbo plugs, with a button change? And that this motors specs are nomore that 25% nitro content and no less than 10% oil? the reason is im a budget racer and currently (have allways) run 20% nitro fuel(Sidewinder 20%-12%oil) and standard plugs, helps me keep cost down,,, is this a good motor for me to buy , does it fit into my fuel and plug choice? thanks guys for all the help, this board and thread is awesome!
justag3 is offline
Old 07-30-2010 | 08:28 AM
  #611
houston's Avatar
U can use any % nitro fuel as long as the engine is properly shimmed for it .
Not sure that the new button design is offered in standard at the moment , I haven't found it yet if it has anyway and I look for that kinda stuff so I know
look me up [email protected] ,I will see what kind of options I can come up with for ya
houston is offline
Old 07-30-2010 | 11:45 AM
  #612
Thank you sir, i will be sending an email!
justag3 is offline
Old 08-03-2010 | 02:57 PM
  #613
deadmancourt's Avatar
i have 3 n21bf's and love them!...i was just wondering what you guys would recommend on a plug choice!...i live in southern california where its always 80 degrees or hotter!....i am also currently running a jp4 pipe and header!...what pipe/header combo do you recommend running on these motors!
deadmancourt is offline
Old 08-03-2010 | 03:01 PM
  #614
merdith6's Avatar
Default Great Question
When the temps are colder outside or even a bit cool I like to run the mccoy mc-8 plug, it's a medium plug, but a bit warmer than a odonnell 99 plug. the 99 plug works great in the hotter months because the engine is running hotter by about 25-30 degrees and a thinner wire in the hotter plugs gets burned up too fast, try the odonnell 99 plug in the BF. and good luck at the races.....
Oh yeah, the most popular pipe is the top end 9886 with the medium or short header, and the 9853ss is my favorite with the short round header.....I have heard the jp4 works great on Novarossi engines, but I haven't tried them and I do recommend the Nova Pipes and Headers.....
merdith6 is offline
Old 08-03-2010 | 10:08 PM
  #615
bad news! i took the backplate off my nova 21bf tonight after practice and noticed the piston skirt had a chunk missing from it!...i found the chunk and quickly put the motor back together and ran it just to make sure it wasnt me that broke it when taking it apart!...i always make sure the piston is @ tdc when taking off the backplate!....the motor runs fine and hits high rpms!...it didnt want to idle,but it was 9:30@ night so i couldnt warm it up!...obviously this is no good but will this piston explode eventually?....
