Like Tree352Likes
NOVAROSSI Engine thread....
Old 08-10-2015 | 09:21 AM
  #8101
Originally Posted by Socket
You put the buggy, not truggy?
You are correct Sir, I meant buggy. My Bad, to be more precise Mugen MBX7R
Italo2275 is offline
Old 08-10-2015 | 08:14 PM
  #8102
Hoese37's Avatar
Originally Posted by Maximo
9886/9853 will both make quite a bit more power then the 9901
Is a 2035 pipe similar to the 9853?
Hoese37 is offline
Old 08-10-2015 | 08:27 PM
  #8103
Maximo's Avatar
not even remotely close.....
Maximo is offline
Old 08-10-2015 | 11:30 PM
  #8104
cczjordan's Avatar
Rb2097 maybe nova9901
cczjordan is offline
Old 08-11-2015 | 07:48 AM
  #8105
Maximo's Avatar
no, not really.... they all make different power bands on different engines.... IMO they are each quite distinct from each other.
Maximo is offline
Old 08-11-2015 | 05:47 PM
  #8106
cczjordan's Avatar
Any advise if i run rb2097 with short manifold for btta/wc engine, power n fuel economy?
Old 08-16-2015 | 12:23 AM
  #8107
sn47som1's Avatar
has anyone tried reds pipes on a nova engine?
sn47som1 is offline
Old 08-16-2015 | 11:22 AM
  #8108
bash bros's Avatar
Default Too cold glow plug???
Just a quick question about tuning & plugs
Can running to cold of a plug cause you to have to lean out the needles quite a bit from where you normally run them?
bash bros is offline
Old 08-16-2015 | 11:52 AM
  #8109
Suspended
http://www.rctech.net/forum/onroad-n...al-tuning.html
Socket is offline
Old 08-17-2015 | 04:56 AM
  #8110
cczjordan's Avatar
Depends on ambient temp, usually cold plug when u running low head shim, extreme hot ambient temp n very lean hsn
Old 08-17-2015 | 09:49 AM
  #8111
capcept's Avatar
Default Roma Issues..
Hello All
I have a Roma that has about a gallon and half run through it since break in and can not get this guy tuned properly anymore, it was running fine since the last time up at the track and then it just did a 360 on me at the track, wont stay running. went back to factory settings and started over with countless attemps and have been just turning screws at this point.. i can get it to idle and once i go WOT and let go it just dies and that is the point im at.. the one thing that i have noticed is the sound of the engine now sounds like its has marbles in it.. could this be bearings?
it spits fuel at idle and as i lean it out that turns to smoke which i think is a sign of the idel needs to come down.. but im not sure if this is normal.
im not sure what else to check here as im fairly new to nitro as you can tell, but it still has good pinch..
running O'donnell 30%, 6.5 Venturi, and Novarrossi C6TGC, 9853/41021
ive replace the fule lines, tested the tank for air leaks..
Any help would be great
Thanks.
capcept is offline
Old 08-17-2015 | 12:10 PM
  #8112
bash bros's Avatar
I'd definitely check out the rear bearing before running it again. What your describing sounds like a bad bearing.
Old 08-17-2015 | 02:10 PM
  #8113
KyoshoRed's Avatar
What is the difference between the mito 4 and the legend 4?
KyoshoRed is offline
Old 08-17-2015 | 05:06 PM
  #8114
capcept's Avatar
so the bearings seem ok, but dont seem ok.. if that makes any sense. they are smooth but there is a point while turning them they seem a little off.. if i place my ear up to the block i can hear at a point while turning the crank that something is not smooth.
capcept is offline
Old 08-17-2015 | 07:08 PM
  #8115
cczjordan's Avatar
If the compression ok, fuel line/tank ok, carb setting is close, then most probably front bearing, try to check it again
