NOVAROSSI Engine thread....
#8251
What exactly do you tune on the MITOS? I know they say tuned from nova. I was looking at the MITO 4 or probably the MITO 7 if I gave you my engine how much would you charge to tune it ?
#8252
on the Mito 4 I enlarge the exhaust port as well as some edge work to the crank ..gives the engine more power and RPM.. on the 7 its the same crank work and some flow work to the sleeve....
#8253
what does that usually go for and if I buy the break in/pre run model, when I send it to you do I need to break it in again past what I'd have to do normally due to the mods?
#8254
Oh my gosh, today's motors compared to my Rex P5X. Here below is the Novarossi RX21P5XS specs I found in the Out of Production area of the website which is like the same as the PR21P5X which is mine:
Displacement: 3,50 cc
R.P.M. (max power): 31.000 RPM
Practical range: 6.000-36.200 R.P.M.
Bore x stroke: 16,26x16,80 mm
Sleeve: 5 ports
Rear ball bearings: steel
Front ball bearings: steel
Crankshaft: 14 mm - Turbo SG
Carburetor: plastic - 8 mm - slide.
Glowplug: Standard (C6S)
Exhaust position: rear
Starting: -
Weight: -
Fuel type: 25% nitro
Pretty much any Nova motor I have been looking at peak power is 36,000 rpm + and has more like the 40,000 upper practical range and have bigger carbs and turbo plugs and I would expect better tolerance and wear over my 10 year old designs.
Sleeve: 5 ports
Starting: -
Weight: -
#8256
Whats the difference between the stock version and this tuned version I've heard of? I went on the Nova site and saw no such thing of a tuned version or is this so called tuned version something you just send to some mod guy to have done?
#8257
Temp is measure during break in, when performance is needed, as long as smoke coming out from pipe on acceleration n hold consistent tune then is good to go.
Tuned version i believe refer to work done on crankshaft, p5 just stock, tuned version need to buy from modder
#8260
Very close to the P5XLT. in a 1 to 10 scale, the Elite would be a rated plus one on everything the P5 was rated... Good, smooth, usable power with low fuel consumption. May not be the biggest bouncer in the bar, but it can hold it's own. Especially in that $200 price range....
#8261
Keep in mind, that on a day that is 45 degrees outside, your engine will run cooler period. On a hot day, it will run hotter. That is why it is more important to tune by performance and smoke trail than by temps.
#8262
#8263
Hello, need info re head button shims on the mito4. I have said motor from Murnan and it came with 0.5mm shims. The nova exploded diagram shows 0.8mm shims. So I'm a little confused as to how many shims I should be running on this motor. I use 30% Nitrolux fuel. Thanks.
#8265
352Likes
