Like Tree352Likes
NOVAROSSI Engine thread....
Old 03-04-2010 | 07:03 PM
  #421
r1harper's Avatar
Run-in on the plus 4c...coming along very well...i think it better than my other one well reg plus 4
r1harper is offline
Old 03-05-2010 | 06:37 AM
  #422
pickle311's Avatar
Originally Posted by J.Sears
I just got a P5X S21 from a friend of mine and the motor is great I have run the Re10 pipe on it and it felt pretty strong what other pipe would you recommend.
+1 on this question. I'll be ordering a P5 in the next couple of weeks and would like to order the pipe I need with it. I currently have an 053 and JP2. I suspect that the 053 is probably a good pipe for it and hope that will be sufficient. I'm wanting 10 minute run times and a nice, smooth, linear power band.
pickle311 is offline
Old 03-05-2010 | 08:51 AM
  #423
houston's Avatar
9853SS/41005 makes great power through the whole power range while getting pretty good mileage , 9901SS/41005 makes ok power but gets great mileage . If you want more low end on either pipe get a 41021 header .
The new 2084ss should be the best of both worlds
And if you want stupid amounts of power and insane top end try either a 9886/41021 , dynamite 086hs or ofna 086 with 41021 header . Another good one is a 2013 pipe
houston is offline
Old 03-05-2010 | 02:08 PM
  #424
Troy Pinkston's Avatar
Originally Posted by "Smiley"
I also tried out a Novarossi Exhaust Cooler. I was amazed at what it did for the engine. It was getting an extra minute of runtime after I put it on. It also did not bog down at all after fuel stops, Cleared out perfectly every time.
I just picked up a couple of these...I have heard good things about them. So they are good for a little extra time huh ?
Troy Pinkston is offline
Old 03-05-2010 | 05:09 PM
  #425
Torian4000's Avatar
I've tried a quite a few different pipes on my P5XS and the Dynamite 086 works the best. Crazy power thoughout the whole range and 10 min run times. I made a mistake and bought the recommended 3005 pipe but it hurts performance in my opinion. Dynamite exhaust systems are inexpensive and just as good as anything else out there....
Torian4000 is offline
Old 03-05-2010 | 07:09 PM
  #426
"Smiley"'s Avatar
Yes. With the Nova Exhaust Cooler, I noticed a 45sec-1min Increase in Runtime. Love mine!
"Smiley" is offline
Old 03-07-2010 | 11:07 AM
  #427
revo61's Avatar
Can you put a turbo plug on a n21r? How much to add the plug? I like to run 20% nitro, what kind of power can I expect?
revo61 is offline
Old 03-07-2010 | 11:32 AM
  #428
houston's Avatar
Yes you can , part # 28002 , minor power increases
More power increase in crank upgrade
houston is offline
Old 03-08-2010 | 08:15 AM
  #429
Night Thrasher's Avatar
Default Max Power C5Q Crankshaft
Anyone here knows where I can buy a replacement crankshaft for a max power c5q engine? or any crankshaft for Novarossi engine that is compatible with this engine.
Thanks.
Night Thrasher is offline
Old 03-08-2010 | 06:04 PM
  #430
dcracing's Avatar
Man, thats great. now i want one.
dcracing is offline
Old 03-08-2010 | 06:09 PM
  #431
Trevor Williams's Avatar
R/C Tech Elite Member
man, I cant see how peeps are hatin' on the 9901ss pipe! I ran mine yesterday with a 41021 on a 6.5mm plus4 C and WOW.......sooooo smooth and gradual, nice linear powerband that had plenty of topend for our backstretch and plenty of low end to clear all the runup jumps.......awesome runtime.......I found my buggy pipeset for the season, no need to look/test any further
Novarossi power baby
I have a 9853ss with a 41005 header coming for my truck!
Odonnell 97T plugs ROCK with 21-4!
Trevor Williams is offline
Old 03-08-2010 | 06:21 PM
  #432
r1harper's Avatar
ditto
r1harper is offline
Old 03-08-2010 | 07:11 PM
  #433
Quick question. I got a few Nova C5T plugs at a steal and was wondering if they would be too hot to run in my +4C. I live in Florida, so the humidity is a little higher. Also, I'll be running 30% Byrons.
Miniracer23 is offline
Old 03-08-2010 | 11:16 PM
  #434
merdith6's Avatar
Default 2084ss ehh...
Looks the same as the 9853ss, but better runtime. Internal changes to the baffle?? I run the 9853ss with the short round header and it rips, but fuel mileage is not as good as the 9886 with the bent header. About 8min compared to 10 with the 9886. I might try the bent header with the 9853. But the 2084 has me curious.....Bet it's perfect for my p5....
merdith6 is offline
Old 03-09-2010 | 10:13 AM
  #435
Thanks.
Anyone please!?
