Like Tree352Likes
NOVAROSSI Engine thread....
Old 12-05-2011 | 04:47 PM
  #1921
CHOAS's Avatar
Originally Posted by whatthefuggy
thanks all! re11 or re10 pipe? with the r21
RE 12
CHOAS is offline
Old 12-05-2011 | 05:09 PM
  #1922
hambone's Avatar
Originally Posted by houston
Used to get rust on bearings and crank before I STOPPED running the fuel/oil out of the engine
Routine now is to dump excess fuel out of tank and let engine cool naturally, no aro !
Using byrons gen 2 fuels , pro driver or race 3000 have PLENTY of oil left in the crankcase and NO RUST
If you do prefer to run fuel out and use aro I recommend rbmods aro and plenty of it
+1 Just dump fuel outta tank.
hambone is offline
Old 12-05-2011 | 06:10 PM
  #1923
houston's Avatar
Originally Posted by savannahmick
I have one with 5 gallons on it and love it! I have a Ninja and it is dusty because my R21 is smoother/longer runtime 13 min./ holds a tune/ and has decent power with RE10 and alum. flywheel. It is a pretty good beginner engine but care needs to be taken during break-in I used the heat cycle method for two quarts but metal pinch didn't go away until 1 1/2 gallon and just got better over time. Yes 30% and running in buggy is fine but I would use something with a little castor oil during break-in like Bryons 11% and the Losi RE10 works great with Nitrotec with 7mm venturi but any of the Losi pipes work well. If you break it in right it will last forever! Good Luck!
yes siree
truer words have never been spoken
houston is offline
Old 12-05-2011 | 07:18 PM
  #1924
houston's Avatar
Originally Posted by Muggydude
I'm curious what you guys think is the better engine now-
Plus 21-4c Team
Plus 21 4btta Steel bearing Engine
Now that both are almost identical in price.
I already have my plus 4c, and I'm happy with that, just curious
More surface area in the exhaust of the plus 4btt , only real design difference
Some like the feel of the btt some dont
I will let someone else go into details
houston is offline
Old 12-05-2011 | 10:03 PM
  #1925
Lille-bror's Avatar
Amazing. Here in Denmark every engine that runs Byron fuel will rust very quick - with or without running the engine dry. Those drivers who ran SideWinder in 2009 and 2010 didn't have that problem but I don't know if the new purple stuff has the same AFO effect.
Lille-bror is offline
Old 12-05-2011 | 11:12 PM
  #1926
PERROTTO's Avatar
Wut I have found to work well is to: dump excess fuel out of the tank, and plug the exhaust when it is at stoage temps.
PERROTTO is offline
Old 12-06-2011 | 03:55 PM
  #1927
blade954's Avatar
Any inside info on Novarossi releasing new engines for the 2012 season.
We are having a change next year and are in two minds of wait and see or get one now.
blade954 is offline
Old 12-06-2011 | 04:00 PM
  #1928
whats the best break in fuel for the r21? where should i buy it? how much should i buy?
whatthefuggy is offline
Old 12-06-2011 | 04:24 PM
  #1929
Seattlelife22's Avatar
I am curious too. I hope novarossi will come out with new ones.
Seattlelife22 is offline
Old 12-06-2011 | 04:25 PM
  #1930
here is your answer...local hobby shop or amain.
Old 12-06-2011 | 04:26 PM
  #1931
houston's Avatar
i recommend byrons gen2 race 3000 blend /11% oil (lots of castor)
Neal at clockwerks likes th hpi purple rush RTR blend i believe , lots of oil i believe 18%
both great break in fuels
i would at least run the first gallon with either of these fuels
houston is offline
Old 12-06-2011 | 10:59 PM
  #1932
Lille-bror's Avatar
Anyone using Novarossi's recipe:
14% ungummed castrol oil (first pressure acidity lower than 0.5) or 7% castrol oil
+ 7% synthetic oil + 80% pure methanol + 6% nitro.
http://www.novarossi.it/files/manuals/uk-general.pdf
I use it for the first 3x5 min + 3x10 min. of break-in. After that I use 20% nitro and 14% oil for the next gallon or so. Then race blend - 25% nitro and 12% oil if I'm out of Byron.
Old 12-07-2011 | 09:43 AM
  #1933
thanks guys for all your responses... Will try putting in ARO
crittertoo is offline
Old 12-14-2011 | 05:59 PM
  #1934
lennybigblock's Avatar
I already had a toro nero in mbx6, I wonder if the bonito is superior in every way? I look for a BONITO.21 7XLBS-and-PLUS.21 4BTTS TUNED. my RC truggy is for a 2.0T
thanks ..
lennybigblock is offline
Old 12-14-2011 | 06:10 PM
  #1935
TX_Punisher's Avatar
So has anyone had a problem with the P5 crank? Is that true the P4 has a stronger crank than the P5?
TX_Punisher is offline
