Like Tree352Likes
NOVAROSSI Engine thread....
Old 12-14-2011 | 06:47 PM
  #1936
juninho_foz's Avatar
Originally Posted by blade954
Any inside info on Novarossi releasing new engines for the 2012 season.
We are having a change next year and are in two minds of wait and see or get one now.
2
juninho_foz is offline
Old 12-14-2011 | 07:03 PM
  #1937
lennybigblock's Avatar
Originally Posted by lennybigblock
I already had a toro nero in mbx6, I wonder if the bonito is superior in every way? I look for a BONITO.21 7XLBS-and-PLUS.21 4BTTS TUNED. my RC truggy is for a 2.0T
thanks ..
i find my anwser on the page 122 ..thanks
lennybigblock is offline
Old 12-14-2011 | 09:14 PM
  #1938
houston's Avatar
Originally Posted by TX_Punisher
So has anyone had a problem with the P5 crank? Is that true the P4 has a stronger crank than the P5?
They are the same cranks when they are cast , they are a little different after some machine/hand work at the factory
houston is offline
Old 12-15-2011 | 07:11 PM
  #1939
for this engine PLUS.21 4BTTS TUNED is good for truggy ??? i have losi 2.0T
Old 12-17-2011 | 08:59 AM
  #1940
houston's Avatar
The plus4 will be a little smooth for the truggy but still make great power
I would suggest something more like the p5xlt or something a little stronger off the bottom than the plus4 for truggy
Hope this helps,
Monty
houston is offline
Old 12-18-2011 | 07:16 AM
  #1941
will a 2084+long header help with bottom end on a truggy without taking away to much top end?
also anyone know where I can get a carb for under $100? I have a plus 4c2010(i believe is the model) almost new but the carb slide is bent
NitroLuver is offline
Old 12-18-2011 | 09:23 AM
  #1942
houston's Avatar
Help with bottom? Yes
Not take away top ? No
Lmk what you need
Send damaged carb in and I will see what we can do with it
houston is offline
Old 12-18-2011 | 09:53 AM
  #1943
bigjayjay1's Avatar
Does anyone know what pipe the re12 is based off its made for their nova engine nitotec .21R21
http://www.amainhobbies.com/product_...Exhaust-System
bigjayjay1 is offline
Old 12-18-2011 | 09:58 AM
  #1944
bigjayjay1's Avatar
I'm real excited I've never owned any novas always an OS guy but Neil from clock has been on my butt about trying. I went to the nova site viewed the bonito internals WOW its a hand sculpture. Will be running the bonito next season CLOCKED of course its going to be fun for sure.
Old 12-18-2011 | 10:49 AM
  #1945
houston's Avatar
they say it is supposed to be similar in performance to 9901 pipe but i have seen it run , its a lil different , similar yes , exact copy no
hope this helps
i would personally stick with novarossi pipes/headers
houston is offline
Old 12-18-2011 | 12:32 PM
  #1946
Lmk what you need
Pm sent
Also I know it should take away top just hopefully not to much
Old 12-18-2011 | 12:37 PM
  #1947
houston's Avatar
Pm sent
alot
houston is offline
Old 12-18-2011 | 06:20 PM
  #1948
Hope this helps,
Monty
thanks for your comment
Old 12-27-2011 | 10:35 AM
  #1949
savannahmick's Avatar
Default Quick question about carbon/rust.
I opened up my R21 Nitrotec and JX.21 to clean and inspect them. When opened up the Nova I noticed alot of rust/carbon on the end of crank and I am curious what causes this because my Ninja was clean as a whistle? I ALWAYS run all of fuel out of my motors and after run oil everytime but I do use Odonnel for the Ninja and Bryons for the R21. I couldn't get the sleeve out of the Nova without risking damage is there a easy way to remove sleeve with limited tools? Anyway I cleaned it out the best I could without removing internals with motor cleaner and put a bunch of after run oil in it. I am afraid the carbon/rust is going to kill my bearings the motor is only 4-5 gallons old. It still runs great! Thanks for info/help!
savannahmick is offline
Old 12-27-2011 | 11:56 AM
  #1950
I have a bonito and I am switching from odonnell 30% to Byrons Gen 4000 pro driver 25 percent should I take out a shim? are engines still ave factory shims installed thanks
koreanassasom is offline
