NOVAROSSI Engine thread....
#1892
hoping someone can explain how theese three engines will preform on the track.
p3xs
p5xlt
21-4
all seem to use the same rod and bearings, so i'm assuming quality of the three is close. i prefer the engine to acclerate quickly, and have enough torque to get the wheels spinning as i prefer to drift/ powerslide through the corners.
thanks in advance mark
p3xs
p5xlt
21-4
P5XLT is the one you want based on what your describing...... especially so if it is Clocked !
#1893
Sorry...
Make sure the wire connection to the throttle servo are straight. Is it sticking when the engine are out of the car?
What car are you running?
#1894
#1896
Yes way too much for a Buggy, but simply awesome in a Truggy ! ...Tho the engine does make big power it is not a light switch at all, it only gets nasty if you want it to...It finds traction like no other truggy engine I have run..doesn't matter if the surface is loose or 100% traction this engine carves up the technical sections unlike anything else...With the ultra long stroke the powerband starts at a very low RPM, which gives it amazing trigger feel and control in the low end.....Has almost a 4 stroke feel in how effortless the engine pulls from the bottom end, which IMO makes it wicked in a Truggy....No other .21 I have ever seen has anything like the Bottom end we are seeing from these engines ..... Even on loose surfaces these engines will still find enough traction to yank the front off the ground...The ultra long stroke gives them something special that has to be felt to be appreciated ! They seem to be able to put more power to the ground with less tire spin then a more conventional shorter stroke engine of similar power.....
#1898
I just finish breakin my plus4T and having trouble with the tuning.It have 3 stage idle.First after reving it will go straight to a good idle and then the idle rise up for about 6-7 sec and came down to a good idle again.Ive try to put my p5 in the same car and tune was perfect.Thats mean nothing wrong with my fuel tank,hose and anything got to do with the car.One of my friend has the exact same problem with his plus4btt with same pipe[9901/021) and ive try to tune it without sucsess.Its runs good on the track tho but just cant get rid of the 3 stage idle..weird!
Can someone help me please?
#1899
Can someone help me please?If the engine are broken in, it sounds like too rich bottom and perhaps an out of tune top. Warm up the engine and set the HSN a little rich.
Try the Bernard Durand way here:
http://vimeo.com/7595905
#1900
Very impressive once you get the tune right how well these novas hold a tune.
#1901
#1902
Thanks for the replys guys!I appreciate it but my problem is 3 stage idle not 2 stage idle.Ive broken in 5 engines so far and never had this problem.2 stage idle is normal when the lsn is a little rich.The idle came straight down after high rev like it should be when lsn is set right but then it rise up for 6-7sec before it came down to normal idle again.No flame out what so ever and running temp is good.i know this is a great engine because i ran nova p5xlt this year and it served me very well.Anyway i might try diff glow plug and play with the shim a little more and see what happen...
This is my setup same as my p5xlt
Glow plug odonell 97t
Fuel Sidewinder 25%
Pipe Losi re12
Shim .70
Fuel Sidewinder 25%
Pipe Losi re12
Shim .70
#1903
Fuel Sidewinder 25%
Pipe Losi re12
Shim .70
Fuel Sidewinder 25%
Pipe Losi re12
Shim .70
change your odonnell plugs often !!! they will wreak havoc with your tune if you do not , i would suggest c5tgc personally
hope this helps
352Likes
