Like Tree352Likes
NOVAROSSI Engine thread....
Old 05-26-2011 | 07:17 PM
  #1141
PowerHouse's Avatar
Originally Posted by merdith6
Thanks for the explanation...
I wondered why the Toro Team felt sluggish on the bottom, The longer header didn't fit in the buggy and I never needed one before. The long header makes more torque so it's really to help out the obviously sluggish Toro team and Bonito engines that for some reason can't be made from the factory to have torque, not even enough for buggy. I would still go with another engine because if you take a 400 dollar engine and still need to modify it to make power then that's some serious cash on one engine. Why not just go with an engine that has torque from the start. that would save money and be less work. I would rather have a plus-4 or p5 tuned or modded to make more rpm than to help an engine get close to making enough torque..I say Novarossi should retire the Toro and Bonito and make a 7 port that is easier to tune, and doesn't require help to make low end power....The closest I've raced and owned is the FMS, and that's being nice......Still not a factory engine.....
My point is, for 400 dollars I want torque and rpm's. Otherwise it's all about the plus-4 and p5 for my buggy....I never miss the extra 5,000 rpms anyway....I'm too busy jumping, and for that I need torque, longevity, and the ability to tune my engine perfectly, I could not do that with the factory 7 ports, from the 367, to the toro, to the team....but I will say the FMS is one badass engine....even though it's picky..I still love it...
I hear ya but to each their own. I love the P5 and Plus 4 in both classes but I was hell bent on making the Toro and Bonito work as there is still a market for them and I sell more of those than Plus 4's once people see them run after modifications. If you get bored one day, throw it in the mail and I will set you up sweet for a good price to sample what I can do with that engine. You may have a new opinion after. I agree, $400+ and then add mods to make it work is a bit steep for some but I guess if you look at the cost of OS Speeds, it puts things back into perspective. Instead of selling it and losing your butt on it, send it in and I will work some magic for you so you can enjoy whats left on it. Unless it has like 8 gallons on it and has been run lean it's whole life to get it to do anything, then just keep it as is at that point but if you have less than 3 gallons and it has been treated well, it should be worth a look. Let me know
PowerHouse is offline
Old 05-26-2011 | 09:27 PM
  #1142
ben73's Avatar
Originally Posted by houston
let me find my write up
did you manage to find it yet? I want to kick off the break in tomorrow.
thanks
ben73 is offline
Old 05-26-2011 | 09:42 PM
  #1143
houston's Avatar
thanks
What's your email?
houston is offline
Old 05-27-2011 | 03:58 AM
  #1144
jin2803's Avatar
What's your email?
Hi Boss need it too for my BTTS... My email- [email protected] ...thanks
jin2803 is offline
Old 05-28-2011 | 03:46 PM
  #1145
Felipe's Avatar
does any one knows the rear bearing size for the plus 21-4C Team?
nova has to sizes 14x25.8x6 and 14x25.4x6.
Felipe is offline
Old 05-28-2011 | 04:13 PM
  #1146
houston's Avatar
25.8mm
houston is offline
Old 05-29-2011 | 04:03 PM
  #1147
Teflon's Avatar
Default Novarossi Plus 21-4 BTT
I just opened the box and the instructions say to replace the shims under the high speed needle and below brass ball under the high speed needle but it doesnt say when? They put replacement shims in the box. Anyone have experience with these shims?
Teflon is offline
Old 05-30-2011 | 02:34 AM
  #1148
mblgjr's Avatar
Technically you should replace them once you've loosened the HSN housing to rotate the banjo. BUT as long as you do not overtighten the housing, you move it a couple times without fear.
However, after that go ahead and replace the washers.
Unless the housing was overtightened from the factory, I've never had to replace them.
mblgjr is offline
Old 05-30-2011 | 02:37 AM
  #1149
mblgjr's Avatar
Originally Posted by GMS_Racing
Anyone know where i can get the new style exhaust gasket
I believe he meant these...
http://www.novarossi.it/eng/news/read.php?newsid=126
mblgjr is offline
Old 05-30-2011 | 05:28 AM
  #1150
GMS_Racing's Avatar
Originally Posted by mblgjr
Yup yup
GMS_Racing is offline
Old 05-30-2011 | 06:59 AM
  #1151
ronjallen's Avatar
Hey guys I have a 21+4c with about a 1/2 gallon and using the 9901ss pipe. I can't seem to get it to run consistent. It will fire right up and once you put it on the track its keeps going back and forth between lean and rich. I've tried different plugs,pipes,carbs and fuel and nothing seems to change it, also new tank and fuel lines. Anyone else having this problem. The motor is to new and has way to much compression for this to be happening. Thanks for any advise before I sell this thing. Also air sealed the carb
ronjallen is offline
Old 05-30-2011 | 07:27 AM
  #1152
ronjallen's Avatar
Also is there suppose to be silicone in the crank? Mine doesn't have any
Old 05-30-2011 | 04:15 PM
  #1153
revo61's Avatar
No not on a stock one.
revo61 is offline
Old 05-30-2011 | 06:37 PM
  #1154
houston's Avatar
thats where i come in
as far as the inconsistent plus 4
not 100% positive but 99% of the time it is usually not your engine that makes the engine run inconsistent , in your case i believe it is either the engine is not run in all the way , your carburetor is wayyyyy out of balance or there is debris lodged in the high speed needle causing inconsistent fuel pressure
hope this helps
houston is offline
Old 05-30-2011 | 07:13 PM
  #1155
mblgjr's Avatar
Also too short of a pressure line will cause you to start the engine with richer settings; then it will lean out as you run the tank down.
On a Nova having the idle gap set excessively high will also cause you to run the LSN too rich and when the engine gets to operating temp, it will come in with an elevated 'buzzing' or racing high-idle RPM.
Good luck.
mblgjr is offline
