NOVAROSSI Engine thread....
#1156
Gday guys
I have done my best to read each page of this thread and im sure this question has been asked
Im planning on purchasing a Novarossi Plus 21-4C 2010 TEAM Ceramic Edition for my losi 2.0 buggy, can someone suggest a pipe and header combo please?
From what i gather a 41021/9901 is heading down the right track?
Thanks for your help.
Cheers
Cheers
#1160
We use the Nova C5TGC or C6TGC plugs. Both work great, the C5TGC gives the best idle and snap / throttle response while the C6TGC will let you run a little leaner.
#1161
what he said other than.. IMO the #6 is the best plug period.. once you learn how to tune with it.. no need for anything else.. I am running the BTTS with 6mm restrictor, 41021 header, 2084 pipe, and C6TGC plug.. I am able to pit at 13 minutes during a race.. This is the best set up i have ever used in my racing career...
#1163
#1165
#1167
Gday guys
Cheers
Cheers
The 9901/ 41021 combo is the most popular for buggy no doubt, buuuuut
I have been using the 9853ss/41021 or 41029 (same header just different car) you would use the 41021 header in a Losi i think...
Anyway the 9853ss just gives more power. The 9901 is smoother, but the plus4 is already smooth so the 9853ss helps the engine rip a little more all the way through the powerband....Not to say the 9901 hurts performance, it doesn't, that's just another option for you to consider....I hope this helps....
#1168
#1170
base adjustments for the plus 4 carb
lsn - hold slide barrel open (engine off ) screw all the way in until you feel it stop run it back out 4.25 turns , hsn - run in until you feel it stop then back off 3.5 turns , idle gap should be approx. .6mm (no insert) or look into carb opening, close slide barrel with idle screw while pushing on the slide barrel to close it until all the opening just disappears then reopen .75 turns
this should get you very close to a "balanced carb setting" , lean the top to adjust rpm
352Likes
so I would save your money
