Like Tree352Likes
NOVAROSSI Engine thread....
Old 01-11-2016 | 10:33 PM
  #8656
Hey guys do you know anyware I can buy this engine from
REVENGE .21OFF with Tuned Pipe and Manifold
Part Number:REVENGE21OFF
Description
REVENGE .21OFF
with Tuned Pipe and Manifold Included in Price
Tuned Pipe: #50003 / Manifold: #41026
TECH SPECS:
Displacement: 3,5 cc
Sleeve: 3 ports
Rear ball bearings: steel
Fronto ball bearings: steel
Crankshaft: 14mm
Carburetor: 9 mm
Glowplug: Turbo (C6TGC)
Tuned Pipe: 50003
Manifold: 41026
As the novarossidirect way too dear on shipping cost
coombes is offline
Old 01-12-2016 | 04:36 AM
  #8657
http://novarossidirect.com/REVENGE-2...ld_p_3235.html
kyosho28 is offline
Old 01-12-2016 | 05:11 AM
  #8658
Too dear in shipping like i said they wanted to charge me 70 bucks for shipping
coombes is offline
Old 01-12-2016 | 07:43 AM
  #8659
Suspended
ebay had them IIRC.
Socket is offline
Old 01-15-2016 | 04:57 PM
  #8660
MURNAN modified has a modded version. You may be able to get a stock revenge from him
kfikes is offline
Old 01-16-2016 | 03:46 AM
  #8661
fizzy's Avatar
mis post
fizzy is offline
Old 01-16-2016 | 06:14 PM
  #8662
vr6cj's Avatar
Picked up a 21-4btta. What mileage you guys seeing that run it. Insert used? Ill be running it on a smaller high traction clay track for now then outside big loosevtrack later. Rc8b3
vr6cj is offline
Old 01-16-2016 | 06:42 PM
  #8663
cczjordan's Avatar
7mm, 9minutes with good tune, to get that extreme runtime would require extreme tune.
cczjordan is offline
Old 01-16-2016 | 08:16 PM
  #8664
toyoter91's Avatar
I ran a 6mm in mine at all times. You can probably drop down to a 5.5 at delta. Tuned right and fully broken in you should be able to be pitting damn close to 10 min
toyoter91 is offline
Old 01-16-2016 | 08:24 PM
  #8665
vr6cj's Avatar
Ok, thanks guys and yeah for delta. Lol
vr6cj is offline
Old 01-20-2016 | 05:04 PM
  #8666
Ok I've searched and read and on and on.....haven't really found what I'm looking for,
Half that is Novas fault with all these damn options!! Lol
Anyway, I want to run a MITO4 in my buggy and MiTO7 in my truck....question is, what pipe and header!!?? 9901 for torque right? 2896 for smooth linear?? Headers!?!?! I even seen one listed that is Mugen specific!?! (I run TLR)
So, any and all help is appreciated! Thanks! Oh, and can someone tell me the pros and cons to the port count or what the port count actually does for the motor?
motoclay is offline
Old 01-20-2016 | 05:14 PM
  #8667
Adam Drake's Avatar
Here's what I run:
Mito 4 in buggy with 9901, 41021 header, C6TGC glow plug, and 7.5mm venturi.
Mito 7 in truck with 9901, 41031 header, C6TGC glow plug, and 8.0mm venturi.
Flash Point 30% fuel for both.
Adam Drake is offline
Old 01-20-2016 | 05:19 PM
  #8668
BigInJapan's Avatar
I run Mito 4 with 2096 and 41031 conical header, 7mm Venturi. Clutch springs 1.05mm and it has excellent bottom end and a controllable mid and top.
The biggest change I found with 4 port vs 5 I was running is the bottom end hit and then tapers off to smoother mid and top. It's the way I like it and it's basically my fave setup in buggy
BigInJapan is offline
Old 01-20-2016 | 05:35 PM
  #8669
Originally Posted by Adam Drake
Here's what I run:
Thanks Adam...
I've seen you get amazing run times too
I plan to run those motors this year....but I can't justify buying 10 different pipe combos to see what they do....id say 90% of the time torque is what I need, with the occasional wide open layout that shows up at Thornhill Racing Circuit (home track). We usually have a Joey track with short run ups....ill run The Drake combo to start and see what's up! Thanks!!!
motoclay is offline
Old 01-20-2016 | 07:44 PM
  #8670
Those Mito engine and pipe/header combos are right on. Chad Phillips in addition to Adam Drake has those being used. I think there is some differences in the restrictor sizes but you can all find what works and tunes.
Anyone run the Jammin Pipes at all.? Or they crap in today's standards? I have them from 10 years ago and I have the JP-1 Bottom end type and JP-2 Top End type. I liked them back then. They are hard anodized and the dirt does not cake onto the pipe which is nice and the stinger outlet is built to last with its design.
Or say I get the appropriate pipe/headers made by Novarossi, does anyone seen them hard anodized by anyone?
190mph is offline
