Like Tree352Likes
NOVAROSSI Engine thread....
Old 01-22-2016 | 07:26 AM
  #8671
Just picked up a brand new keep off 4 , have a few pipes I can run , jp3 , a 053 and a 2096 with a dent an 41021 header , what's the recommended pipe ? I have read some good things on the 053 on the keep off , thanks !
swayysta is offline
Old 01-23-2016 | 06:02 AM
  #8672
cczjordan's Avatar
I personally like 2058 with 7.5 venturi
cczjordan is offline
Old 01-23-2016 | 06:16 AM
  #8673
Maximo's Avatar
053 and get a 41001 manifold........use the 41021 is your on a slippery track and use the 41001 if your on a bigger track and want more giddy up
Maximo is offline
Old 01-24-2016 | 06:37 PM
  #8674
keithw11's Avatar
I picked up and Roma .25 7 port for my truggy what pipe would you guys recommend for thi motor?
keithw11 is offline
Old 01-24-2016 | 09:05 PM
  #8675
houston's Avatar
you can pick what you want of course but when i was testing the engine when it first came out i was most happy with 9853ss 41021 , double bent headers like 41001 41019 41005 etc were a bit too much power to race with imo
hope this helps
houston is offline
Old 01-29-2016 | 01:56 PM
  #8676
Suspended
New P5 is out. Went back to a cast piston. Has a filled crank though.
Socket is offline
Old 01-29-2016 | 07:28 PM
  #8677
i got a roma .25 in a deal on the forsale thread. it came with one of the screws locked with out a slot for a screw driver on the back plate and some engraving on the mounting edge a team motor i think anyone seen this before??
KEITH is offline
Old 01-30-2016 | 01:39 AM
  #8678
Roelof's Avatar
That sounds like a teamdriver engine.
Roelof is offline
Old 01-30-2016 | 07:05 AM
  #8679
i can see also that they have some done some work at the back plate like the older novas ,,different work ,.....i would like to see if they also worked litle more at porting and the volume of the crankcase,compared with the older p5 xlt
nick m is offline
Old 01-30-2016 | 07:23 AM
  #8680
bash bros's Avatar
According to the part numbers its the same old p5 crankcase. The sleeve appears to be the same too. The new 85007 crank probably makes the biggest difference. I'd assume it's just a filled 15007, which would mean it has a larger bore and a little more timing than the 15009 crank the used in the older p5xlt.
bash bros is offline
Old 01-31-2016 | 12:00 AM
  #8681
omarwashington's Avatar
Opinions on using p3 glow plug on a p5xlt
omarwashington is offline
Old 01-31-2016 | 12:17 AM
  #8682
am
To hot
am is offline
Old 01-31-2016 | 12:36 AM
  #8683
cczjordan's Avatar
If really wan to use os plug, p4 is preferable p3 too hot n wont last
Old 01-31-2016 | 08:57 AM
  #8684
Default N21 3cq
Has anyone of you guys had any experience with this mill?I know...I know...it's not a $400.00 mill and the fastest the on earth.I'm a sport racer and have had a lot of luck with more budget mills.just found this gold head, standard plug with a pipe for a little over $100.00.any help would be appreciated.thanks
smash8ight is offline
Old 01-31-2016 | 11:05 AM
  #8685
Suspended
What are you wanting to do with it? Zip up and down the street, or race competitively?
Socket is offline
