NOVAROSSI Engine thread....
#1262
very disappointed in nova rossi at the moment one gallon and not good always preheated never ran lean nad never got a full race tune but never finished a race flamed at one point or another never held a tune never got over 250 to my knowledge am yet to disassemble to inspect the internals but low compressionfor what it should be, i have had other brands that i just heat cycled twice including a rossi blackk magic that ran from 6 to 12 gallons on trinity platinum fuel not odonnels that i used in this one
#1263
#1266
just because it looks good does not mean it is. Can you push the piston past the wear marks pretty easily. How is the pinch when the motor is heated up. I had a motor that looked great but had no pinch, and basically yea I sucked in dirt and ruined the motor.
#1267
Hi all...I am just want to ask,,, First I am planning to change my Novarossi plus 21-4 standard underhead into turbo underhead, so can I just remove n plug the underhead directly as simple as that??? or I hve to change other component too?? Second, I am also planning to change my novarossi plus 21-4 standard ball bearings into ceramics ball bearings, is that worth of money n value?? Thx all
#1268
when removing or installing a cooling head remember to undo and redo bolt tension in and even criss cross pattern upping the amount of tension/torque on the bolts each pass through the X pattern and do not overtighten
unless you are well versed in bearing change out you will more than likely do more harm than good to the engine but ceramic bearings are an improvement to engines efficiency fosho
hope this helps
#1269
I appreciate your commentss but all that has been checked doesnt push past the point and compression about the same hot or cold next time I run it I am going to use a bigger restrictor to see if that helps, never had a finicky tuning problem like this in 8 yrs
#1270
when you get the lsn close , half hour adjustments make a difference with the long lsn carburetors
also check that your hsn housing isnt broke , i have seen a few break right where the threads end
#1271
the lsn monty, high speed just doesnt seem to make much difference at all but thanx will examine it closely,ran a different motor today ran okay after tuning issues for sitting a year but it ran steady
so i know it isnt a tank or line issue
#1272
i will take a look at it if you would like
#1274
the underhead switchout is as simple as that almost , make sure you transfer all the head shims from one to the other , should be 2 x .30mm aluminum and 1 x .20mm copper shim in total .
hope this helps
hope this helps
352Likes
