Like Tree352Likes
NOVAROSSI Engine thread....
Old 02-19-2012 | 02:18 PM
  #2176
houston's Avatar
Originally Posted by GMS_Racing
If im running a BTT on 30% should i remove any of the head shims?
Not necessary , but rearranging shims (requires other shims) to achieve .70mm will feel a bit more responsive but I wouldnt suggest doing so til after metal to metal friction is gone
houston is offline
Old 02-19-2012 | 09:15 PM
  #2177
Lille-bror's Avatar
Originally Posted by houston
silicone filled intake ramp does do a few things , most noticeably the reduction of the staged idle by filling an airpocket that completely disrupts incoming flow of air/fuel when going from high vacuum to low vacuum on the intake of the crank , noticed a HUGE difference in the way the engines tuned off throttle and it threw me for a loop back in '06-'07 ish when the 821b was the first engine to come with the lightened crank that was unfilled . one thing i can tell ya is every single one of my multi repeat customers from all over the world have tried both and prefer a filled crank , we all do things a lil differently , we all have different opinions , we all feel things that others dont .
Thanks Monty.
Makes sense
Lille-bror is offline
Old 02-20-2012 | 07:36 AM
  #2178
CanyonCarverR1's Avatar
What do you guys use to pre-heat your engines? I have a heat gun, buy I'm looking for something I can turn on and walk away from for a bit.
CanyonCarverR1 is offline
Old 02-20-2012 | 07:51 AM
  #2179
J.Sears's Avatar
Competition heater. It's the greatest thing sense sliced bread.
J.Sears is offline
Old 02-20-2012 | 11:00 AM
  #2180
houston's Avatar
Agreed!
Comp heat is THE WAY!
houston is offline
Old 02-20-2012 | 02:01 PM
  #2181
handyman77's Avatar
Hey Houston, I have a question, I have a bonito with about 1 gallon now and I am using the 6.5 insert so is that a good insert or should I go to a 7 or 7.5 I run this in a truggy, also how would this affect the run times? I am getting about 8min right now
Thanks in advance
handyman77 is offline
Old 02-20-2012 | 06:57 PM
  #2182
davet323's Avatar
I got a +4 BTT.. 3 litres old, It flames every fuel/pit stop sometimes in pit sometimes 1/4 lap out. Can someone tell me why? I checked all lines/tank all are ok. Its flames after refill when tank is close to empty. runs great up to the pit stop.
Any help would be great.. Cheers
davet323 is offline
Old 02-20-2012 | 07:20 PM
  #2183
hookem34's Avatar
R/C Tech Elite Member
Have you tried to lean the LSN an hour or so?
hookem34 is offline
Old 02-20-2012 | 07:35 PM
  #2184
Maximo's Avatar
what fuel and glowplug do you use ?
Maximo is offline
Old 02-20-2012 | 07:48 PM
  #2185
strngdze's Avatar
I had the exact same issues recently. It turned out being my manifold gasket between the pipe & header. Looking at it from outside it looked fine, but once I separated the pipe & manifold, I could then see the gasket was trash.
It ran OK under throttle because the pressure was still high enough to help push the fuel. The flame outs occurred at idle because there was not enough tank pressure due to the fact it was escaping between the pipe & manifold.
Just something else to check.
strngdze is offline
Old 02-20-2012 | 07:58 PM
  #2186
davet323's Avatar
Nitro X 25% with C6TGH Nova plug.
I was actally with Savage sam at Geelong last weekend when it was happening. But he wasn't the problem..LOL..
Neal
davet323 is offline
Old 02-20-2012 | 08:08 PM
  #2187
Maximo's Avatar
Neal
what oil % ....your plug may be a touch too cold , which would make the engine more sensitive...
Maximo is offline
Old 02-20-2012 | 08:53 PM
  #2188
houston's Avatar
Like Neal said that plug is the onroad plug c6tgh is pretty cold compared to c6tgc
Like strangdazd says , check all fuel pressure/delivery components before blaming it on the engine, 99% of the time you will find something wrong
Is it a mugen?
houston is offline
Old 02-20-2012 | 09:20 PM
  #2189
davet323's Avatar
Is it a mugen?[/QUOTE]
Yes it is a Mugen
Sorry the plug is a c6tgc
davet323 is offline
Old 02-20-2012 | 09:22 PM
  #2190
houston's Avatar
Is it a mugen?
Yes
how did I know ?
Tell tale sign your novarossi isnt properly tuned , runtimes are not good
houston is offline
