Like Tree352Likes
NOVAROSSI Engine thread....
Old 03-12-2012 | 09:24 PM
  #2296
Kurt04's Avatar
I just picked up a Truggy with a 821B in it. Can't find much info on this motor.... Any help?
I know its an 8 Port .21 but thats about it.
Kurt04 is offline
Old 03-12-2012 | 09:59 PM
  #2297
houston's Avatar
what do you wanna know? and what do you need to know ?
just ask about anything specific and you will get help you need bro
i personally know a heap on that engine
houston is offline
Old 03-13-2012 | 02:50 AM
  #2298
Hello all,new novarossi owner/fan here and had a couple Q's.
I got a really good condition used team toro Nero and was wondering what temps it should be running at?
Also it seems a bit low powered but that was after swapping a picco jl red dot .28 so I'm wondering if that makes the toro seem slower,but this question is would it be worth it to send it in and have it modded up fairly extreme?
Will it push a very noticable power difference?
Also I'm running werks racing blend 30% and I belive stock shimming but not 100% on that,what should the proper shimming measure out to be?
Thanks in advance for any answers givin,also and modders out there pm me with some mod options for my motor,I plan to race track only no bashing.
bra-tac is offline
Old 03-13-2012 | 07:18 AM
  #2299
bigjayjay1's Avatar
Are you a good tuner is your motor tuned correctly if you need more help contact Neil at clockwork engines it will help you either way even if you don't buy an engine. His engines are one of the best in the industry you would be suprised who runs
bigjayjay1 is offline
Old 03-13-2012 | 08:47 AM
  #2300
I can tune fairly good,I just may have expected more out of this motor than its got.
Could I send it in to get clocked?
Will it be worth the time and money to mod this specific mill?
bra-tac is offline
Old 03-13-2012 | 06:16 PM
  #2301
Kurt04's Avatar
8-ports are torquey right? So it would make a good truggy motor?
It had an O'Donnell 97T in it, that about right? I have a gallon of Byron's Gen2 30%, that ok?
Kurt04 is offline
Old 03-13-2012 | 07:16 PM
  #2302
bigjayjay1's Avatar
Just pm Neil he will answer your questions he never sleeps he's not human
Old 03-13-2012 | 08:34 PM
  #2303
houston's Avatar
the 821b was a screamer
good truggy engine , clutch it up a bit , they came standard plug unless someone switched it out for turbo , 97t are ok but c5tgc or c6tgc would be much better , byrons gen2 race 3000 or pro driver will be great
what pipes you got ?
houston is offline
Old 03-13-2012 | 10:43 PM
  #2304
Kurt04's Avatar
What would be a good clutch/flywheel setup?
It does appear to have tapered plug seat.
Came with Dynamite Platinum 053MR.
Also the Carb has a REX sticker on it and I don't have any venturi's.
The track I will run on most is average 1/8th scale size. Open, flowy layout. Good sized jumps but nothing insane.
Is everything on this motor the same as the 421B except the sleeve?
Kurt04 is offline
Old 03-13-2012 | 11:59 PM
  #2305
houston's Avatar
you mean is the sleeve the same and everything is different ?
its alllllllll novarossi man , lmk if you need anything
decent pipeset on that engine for a truck
clutch? what kinda car you running ? i have been very happy with the buku power clutch lately but am also a big fan of the werks clutch system
houston is offline
Old 03-14-2012 | 05:41 AM
  #2306
I was on the screen to email him and just said screw it and called him up,we chatted for quite a while,he's a real cool dude and knows his shiz for sure.
I ended up gettin one of his clocked novarossi bonito and opted for his break in service,he says I should have it by the weekend!
I can't wait to try my first modded .21!
bra-tac is offline
Old 03-14-2012 | 08:29 AM
  #2307
Kurt04's Avatar
Jammin' X1-CRT. I was looking at an M2C Quick Change 4 Shoe System but the Buku system looks really easy to tune.
If I run on a tighter track what would be a good pipe set to consider?
Kurt04 is offline
Old 03-14-2012 | 08:50 AM
  #2308
p@p@nut's Avatar
A little help here. I got a brand new nova plus 21-4T. The thing is, the engine comes with its own tapered collet. Should i use the nova one or remove it and use the one provided with the car kit plus the shim?
p@p@nut is offline
Old 03-14-2012 | 09:56 AM
  #2309
losi_racer's Avatar
The one with the car is fine. I have never used the included collet
losi_racer is offline
Old 03-14-2012 | 10:04 AM
  #2310
houston's Avatar
That dyn053mr will be good for what you got going on
M2c clutch system should be great on that setup also , the guys who run Neals engines shoul4 be able to give you some great clutch tuning advice on that clutch system
houston is offline
