Like Tree352Likes
NOVAROSSI Engine thread....
Old 04-07-2012 | 04:27 PM
  #2446
Questions?? hey
hey guys acquried a p5 new done by clockwerks of canada with matching nova pipe what should i really expect from this engine in a k car mp9 drivability tune and economy this is only my second nitro engine,coming from a .21 jammin and jp3 pipe
DR.Vanostrum is offline
Old 04-07-2012 | 04:50 PM
  #2447
hookem34's Avatar
R/C Tech Elite Member
Expect pure insanity! That engine will scream and put a permanent smile on your face. Just make sure you dial in your radio throtle settings and tune your clutch properly for buggy.
hookem34 is offline
Old 04-07-2012 | 05:35 PM
  #2448
psr's Avatar
psr
Originally Posted by TommyBlazin
dont 2nd guess novarossi bro that would be a big mistake..i ran the plus 4 <first version> modded by houston, and i have to say it idled all day, held a perfect tune, power for miles,pitted at 10 min with PLENTY i mean PLENTY in tank, probably one of the most "usable " powered novarossi's i ever ran!!, yes post your pipe selection/plug/fuel/ and did you break it in, buy it 2nd hand...novarossi's are the ferrari of nitro, and they make more models than the plus 4, you can have as much power as your car/truggy can handle, and than some.....
ok its now in a mp9 i run 30 % nitro with a 9901 pipe and a novac6 plug both items are brought new tha latest one has only just on 2 ltrs of fuel i know its not drop its nut yet
we have a few people wjho race theses were i am some set theres up slightly rich on the bottom and lean up top and the other groups say kept it lean on the bottom and rich
both engines are bog stockers run time is awesome over 11 min with fuel still in tank no problems
psr is offline
Old 04-07-2012 | 05:51 PM
  #2449
TommyBlazin's Avatar
sounds good so far, AND yes you are far from droppin nuts,whats your clutch setup like, and weight of flywheel <aluminum or steel>
TommyBlazin is offline
Old 04-07-2012 | 09:29 PM
  #2450
aussies1129's Avatar
so has anyone run the roma was thinking of trying it in the truggy, but would like to see what people are getting for run times.
cheers
aussies1129 is offline
Old 04-07-2012 | 09:32 PM
  #2451
what kinda run time ??
Old 04-07-2012 | 09:33 PM
  #2452
houston's Avatar
cheers
its not in public hands yet , i watched billy's at nitro challenge fairly closely , it has mucho BALLS
something to remember , two different people can take the same exact engine setup and one could get 7 min and the other get 12 , its not "just" the engine guys
houston is offline
Old 04-07-2012 | 11:08 PM
  #2453
I believe that I myself have been to heavy on the throttle
cheers
Old 04-08-2012 | 02:43 AM
  #2454
has anyone used the Protek bearings from Amain in there Novas?
Looking to replace all mine and looking at those. I see they also offer ceramics for not much more, is it worthwhile going for the ceramic one?
http://www.amainhobbies.com/advanced...filter_cat=158
Also, does the Hudy bearing puller tool work fine on Nova sized bearings?
thorns is offline
Old 04-08-2012 | 03:08 AM
  #2455
The Hudy bearing puller has been one of the best r/c investments I've made in a long time. Yes, it fits Nova's.
FLDan is offline
Old 04-08-2012 | 03:38 AM
  #2456
psr's Avatar
psr
stock mp9 clutch and fly wheel set up alloy clutches alloy fly wheel
psr is offline
Old 04-08-2012 | 03:54 AM
  #2457
the hudy bearing puller is awesome removes and installs bearing very easy, a guy I race with tried the proteks but I remember him saying that the nova bearings are not cheap but the quality is the best I think the nova steel bearings are probably better than other brand ceremics
Old 04-08-2012 | 04:25 AM
  #2458
Thanks guys, helpful stuff!
One other quick question in regards to the rear bearing (Nova P5), is it 25.4, or 25.8 OD?
In the title here is says 25.8, but then in the text 25.4.....
http://www.amainhobbies.com/product_...P5X-421BS-528X
thorns is offline
Old 04-08-2012 | 06:27 AM
  #2459
you should be set, what are your needles at, and about what temps is she running?
Old 04-08-2012 | 06:37 AM
  #2460
xc7's Avatar
xc7
it is 14x25.8x6mm
xc7 is offline
