NOVAROSSI Engine thread....
#2461
#2463
Ive seen almost every engine get 7min and 12min in different hand
Recommend 2096ss/41021 for pipeset , 7mm restrictor , c5tgc or odonnell 97t plug for break in then c5tgc or c6tgc after engine comes in to its own
#2464
Just tried my 2084 for the very first time today. Good damn, it gives bottom end power!
Very impressed. We needs a lot of bottom on our local track, so that pipe is perfect
.. and nice crispy sound btw.
... and nice crispy sound btw.
#2465
#2466
Have you tried or are you guys allowed to run 9853ss pipe Bjarne?
#2467
So whats the going rate on a P/S/R on a BTT?
Short story, My less than 20 tank old BTT went from metal pinch to OS compression from a sweet pitstop featuring 50/50 dirt to fuel.
Engine still runs and idles, but i dont know how long she has. In the process of tearing it down but i dont have any Flat head drivers (wtf put some real screws in there nova). I can see a nice dirt pile in my crank though through the intake.
#2468
#2469
Please suggest the correct bearings for the Plus 4?
#2471
was thinking of a novarossi roma with a 2084/21 pipe combo in my truggy I wonder how that combo would go??? what sort of combo are the pros using with this engine at the moment and would be good to know what carb inserts?? maybe 7mm? cheers
#2472
edit.... Not trying to take anything away from the 2084....its just that the Roma most likely already has a strong bottom end, so adding on a 9853 type pipe may be going too far in the one direction...usually large engine do better on RPM type pipes, as the bigger engines already have a pile of low end torque and usually need the most help on the top end....!
#2473
You may want to find screwdrivers that fit those nova screws. I have personally modified a couple of flat heads, one for the head and one for the backplate screws. You just have to be careful, as they'll strip easily if you use the wrong size tool.
Most places selling engine bearings will have a list on which bearings fit which engines.. I can tell you that most .21's and .28's require 7X19x6 size front bearings. You just have to do a little research. Hope this helps.
352Likes
