NOVAROSSI Engine thread....
#3062
I would say C6G. It's what I've run in most my Nova Rossi with a std head button.
http://www.novarossi.it/eng/products...x.php?plug=ssu
Ross
#3065
i'm looking for some advice on a good engine for my 1/8 buggy. i want something as smooth as possible, it doesn't need to make a bunch of high end power, just smooth, easy to drive, and fuel economy. i am used to 1/8 electric where the power comes on smooth. top two on my list are the +4 and the P5xlt, but it looks like the P5 is geared more towards truggy. any recommendations would be great
#3066
#3069
#3070
#3071
How many turns out on the LSN and HSN for a properly tuned 21-4BTT?
I thought I saw on here 3.5 or 4.5 turns out on the LSN. That is way off of what I am at now.
I am sitting a hair in from flush on the LSN. Its about 1.5 turns out total.
#3072
I have replaced all lines, gaskets, and done tests to make sure I do not have a leaky bearing and all passed with flying colors. I just think the motor still is not completely broke-in and once it loses more pinch I will be able to lean the LSN a little more. I have a well broken in P5 and I am at 4 turns out on the LSN on it and it is fine and is perfect.
#3073
My Btt/a is just shy of 2 gallons and hasn't dropped its nuts. My LSN is 4.75 out from bottom (just in from flush) Any leaner and it won't run right and stall. My hsn is just out from flush. Its making insane run time and perfect power. I preheat before everyrun and if I am in a bump up position, I'll put the heater on while waiting for the next main. Still very hard to turn over by hand when up to temp.
to reset your needles LSN 4.5 and HSN is 4 from bottom, Idle gap is .6mm with venturi out. But that would be after fully broken in. I tried to do 4.5 yesterday and it wouldn't run right.
#3074
#3075
Hey guys, what temp are you finding the Roma .25 is running best around. I have been running around 220. But as this is my first nova, and I keep reading temps around 260 - 280. I have got about 1 gallon through it maybe a little more. I'm in Brisbane Australia, about 74 m above sea level. I use standard no 6 plug with 41021/51020 and 25% fuel.
352Likes
