Like Tree352Likes
NOVAROSSI Engine thread....
Old 04-16-2020 | 09:15 PM
  #10531
kgombe's Avatar
Is it this
https://www.absolutehobbyz.com/novar...-bearings.html
kgombe is offline
Old 04-18-2020 | 06:04 AM
  #10532
HaulinBass's Avatar
im guessing its this one
HaulinBass is offline
Old 04-18-2020 | 06:13 AM
  #10533
cbh148's Avatar
Couldn't reply till now because of 5 post / 24h limit Lol but yes ^that's^ it, the white headed Bonito. Hopefully this repainted old stock garbage will hold together for a few gallons as I make the turn marshals blow past their Fitbit goals with flying colors.
cbh148 is offline
Old 04-18-2020 | 07:04 AM
  #10534
HaulinBass's Avatar
well my silver head "limited edition" karma has 8+ gallons and has literally never flamed or stalled once, not bad for old stock. the biggest problems with the limited editions is they tend to come with the carbs no one wants. Throw the carb from your p5 on it if you still have it and run your 053 pipe.
Old 04-18-2020 | 10:21 AM
  #10535
cbh148's Avatar
Right on. From what I can tell, my P5 is specifically the P5XLT and not the P5XLT/16 or the P5XL. The engraving on the bottom reads 0587/14. Is the 14 indicative of manufactured in 2014? The new Bonito reads 0885/19.
Browsing the Out-of-production engines page on Novarossi's website, and comparing the 3 different P5's there is what leads me to believe mine's the P5XLT since the crank case is black, the crankshaft doesn't have a silicone ramp, the carb is the normal reverse style and it has no midrange adjustment screw. If that's correct, then the exploded view sheet shows it's a 24063, which I'm hoping is the better carb you mentioned rather than the 24069 that the new Bonito's exploded view sheet shows it has.
cbh148 is offline
Old 04-18-2020 | 10:49 AM
  #10536
HaulinBass's Avatar
if the bonito comes with the 069 carb thats the one i prefer
Old 04-18-2020 | 06:52 PM
  #10537
Default mephisto opinions
Thinking about a mephisto, currently have a mito 4 and p5. Haven't seen too much on it in this thread...any thoughts/opinions/experience with this motor? Thanks
JerseyGTS is offline
Old 04-19-2020 | 07:54 AM
  #10538
cbh148's Avatar
From what I can tell, my Bonito's needle tip will fully exit the jet at WOT, but my P5's won't. Don't know if that's just a product of different LSN settings, or if that's part of the assembly differences that coincides with one of these carbs being the preferred model over the other.
cbh148 is offline
Old 04-19-2020 | 07:53 PM
  #10539
J.Whiting's Avatar
Super Moderator
From: a very small town in wisconsin that is in the middle of absolutely no where
i really liked my mephisto.. the manta is the same motor just no dlc crank.. same internal parts.. both ran really good for me when i ran them.
JerseyGTS likes this.
J.Whiting is offline
Old 04-20-2020 | 10:32 AM
  #10540
petersen114's Avatar
I am currently running a Nova Rolling w/ a 41021-9901 header pipe combo in my truggy. I found a 2096 that I forgot that I had. What will the 2096 do for the Rolling with the 41021 header.
petersen114 is offline
Old 04-20-2020 | 01:54 PM
  #10541
J.Whiting's Avatar
Super Moderator
should give you more top end but will loose a bit on the bottom end
petersen114 likes this.
Old 04-23-2020 | 09:00 AM
  #10542
So is it 1.5 or 1.25 turns on the D screw?
alex_blais is offline
Old 04-24-2020 | 05:50 PM
  #10543
houston's Avatar
i have found the needle seat adjustment to work best at 2.25 turns from all the way in .... this allowed much more usable adjustment of the low speed needle ....... mush less finicky and stayed more consistent .....
hope this helps
Winner's Circle likes this.
houston is offline
Old 04-29-2020 | 04:57 PM
  #10544
Default Mito 7 or rolling?
It’s for a truggy. Seem pretty similar, any body know any differences?
ohiofordfan is offline
Old 04-29-2020 | 05:03 PM
  #10545
J.Whiting's Avatar
Super Moderator
i ran the rolling in my truggy and really like it.. both are long stroke engines with very similar specs. either will be just fine
