NOVAROSSI Engine thread....
#9976
The Paloma is a decent engine for the price but the Rolling is a much nicer engine for the extra $50 if you want a 7port. Any of the 5ports are also a good choice. I am using the Rolling in a buggy right now and really enjoying it. I have an Adam Drake edition 5port that has also been a great engine in buggy and now I have it in my truck. I have also ran the keep-off 4port. It was a great little engine in buggy. Just keep in mind that the extra $30-$50 more for some of the newer engines are well worth it.
Rex paloma Ltd edition
And seems to be running for 7+ gallons.
Is the rolling able to do 12-13 minutes?
My track is technical with no long straights and running a buggy.
#9979
41005/9901 makes for a fairly easy to drive setup and super easy to tune,41001/9901 makes it agressive and quite punchy. 41021/9901 gets a decent runtime but feels a little flat. 41001/2096 i really like but gets a little less runtime than the 9901 setups.
my buddy has the 41021/2096 setup on his in buggy and it seems to tame it down quite well to run in buggy
#9980
On my Rolling I have used 41021/9853(lots of power)and 41021/9901(good power and mileage)and 41021/9886( lots of top end not the greatest mileage). These are just my findings and opinions. I like the 41021/9901 the best for the all around balance between power and mileage. 41021/9853 would be my second choice.
#9982
Hi
I have an old keep off 21-4 engine. I've heard that I can use mito 4 parts. Looking in the exploded views the rod, the piston pin and the front bearing are the same. Anyone know if I can use the piston, the sleeve and the rear bearing?
thanks
thanks
#9985
Hey guys, in the process of building a new Truggy that I am going to make it an on-road truck. Stiff suspension, thick diffs, modded engine, Alum C-cups, tonnns more. I am in the market for a new engine, just not sure what I am going to pick up. It's going to be a drag/on-road Truggy, but not going to just throw handling out the window just for some extra MPH on the radar. I need suggestions on what to put in there for sheer poweeeer and I want the reliability of a Novarossi. Should I be looking at the on-road .21's or should I be looking at the .28's for the weight of a truggy? Thanks guys, hope someone can point me on the right path.
#9986
Hello
And the following friends have a Novarossi Engine Rebrand (RB Products).
After a few years with the engine stopped, yesterday to remove the screw that holds the carburetor to the block, I split the screw head, and now where can I find a screw that of in my RB, a Novarossi screw is compatible?
And to dismantle the carburetor the rubber that has the left side in the engine simply fell apart in two, if you buy the rubber Novarossi gives in my RB?
Thank You
Thank You
#9988
[QUOTE = Roelof; 15291425]. Sim, o parafuso é padrão em todos os modelos Novarossi, você pode também tentar obter um parafuso M2.5 que ele realmente é [/ QUOTE]
Thanks Roelof, I'll try to buy here in a tool house.
And in relation to the needle rubber of the carburetor LSN has to be even Novarossi right?
Thank You
Thank You
#9989
Thank You
Thank You
#9990
Alright so I'm trying to get my 28-8 completely tuned. I thought I had it dialed until today I took it it and got it up to temp and made several high speed passes. The idle was pretty much a 3 step instead of a 2 step. If I had let it come in and sit for 4 seconds or longer after a WOT pass, it would be loaded up and kind of sluggish once I hammered the throttle for the first couple of feet. From my knowledge, I should be able to bring it in and let it idle for 10 or more seconds and still get a clean pull unless it's an excessive amount of time idling. So I leaned my LSN and backed off on the idle screw. My idle gap is somewhere between .5 and .7. I eventually got it to where it could idle longer than 5 seconds without loading up and still having a clean launch with a very light trail of smoke after hammering it until about the midrange it started to have a more noticeable smoke cloud. Am I going in the right direction or am I possibly going away from the tune? The idle seems to be getting closer to a 2 step at the current tune.
352Likes
