NOVAROSSI Engine thread....
#9226
What can I do to get some fuel mileage out of my plus 4 btt wc engine? I'm running a jq car with 3 shoe all aluminum clutch with 1.0 springs all around. 5.4 restrictor, reedy 2035 pipe. 7 1/2 is about its max runtime. I'd like to make 8 1/2 comfortably. I have an ofna 086 with double bend header I could run, or a reds 2104. I guess I don't know the trick to mileage seems everyone runs better than me. I'm also using byrons 30% nitro/8% oilfuel
#9227
mine runs 10min easy with a 2096/41033 with 6mm restrictor sidewinder pro blend 30%on a fairly large open track.
just to be sure your carb gap is about half mm, your total throw for the carb is slightly smaller than said restrictor and you have a proper race tune on the lowend?
a difference in 3 minutes is pretty large are you dragging any bearings? i run the tki4 and its not really known for good milage
#9228
2096/41021 for softer bottom with good top and almost same fuel consumption to 9901/41021
9886/41021 best powerband but thirsty
Run 7mm venturi, 5.4mm you race on extreme small track?
I believe the tune is messed up, check if lsn is extremely rich
#9231
#9232
#9233
#9236
#9237
About how much life should I get out of the Elite5/8 line of engines? Mine has compression, but not a lot of pinch. Debating on getting a new p/s vs just calling it done if this line doesn't get a lot of life.
#9238
Nova engine with race tune usually 3 gallons / races, more than that i consider godlike tune, 3 gallons / races mean no mysterious flame out or inconsistent power
#9239
Ive got two motors with well over that. The btt posted earlier is Closer to five and half to six and a second set of bearings and still will hold its own weight when you hold the motor by the flywheel.that thing has to be the exception to the rule as my keep off 4 which is pretty close to the same motor has about four on it and there is zero mechanical pinch.
I don't think I ever put the too kill tune on the btt but it runs ten easy at the large open local track.
352Likes
