NOVAROSSI Engine thread....
#9076
My last Nova Plus 4 had over 8 gallons on it with original rod and bearings with no maintenance done to it. Fresh filters when needed and engine heated before starting. If you break in a Nova correctly, it will last a long time. Of course don't run lean and check for wear periodically.
#9077
Although there are those freak things that happen....
#9078
Yes, I bought one a while back and finally got around to trying it in my Elite 8 last night. I'm not sure about any increase in power or mileage yet since the engine is still pretty new but the biggest change I noticed is how easy it is to tune the engine. It seems to drop down to a nice idle a lot quicker with the eb plate. I've still got a little experimenting to do but so far I like it.
#9079
#9080
#9081
When do you guys typically change the engine conrod? I have a keep off 7 that had 3 gallons before I got it rebuilt. Afterwards I ran like half a gallon to a gallon now my bearings are shot and I am in the process of changing them. Should I change the conrod now or should I check for signs of wear to make that decision?
#9086
P/S/R & carb assembly are part numbered the same.
Mito gets the offset carb base/induction and altered crank to match.
Technically the Mito is the flagship of the 2.
You can decide if the price difference warrants using one over the other for your application.
240 vs 270.... is the offset carb/crankcase worth it?
#9090
My bt4 plus bogs on the straight and runs super hot yet my HSN is way rich like 6 turns out from bottom. I replaced the exhaust gaskets and checked internals and nothing looks broken. No fuel leaks through front bearing. Still feels like I have lots of compression. Less than 2 gallons on it. Any suggestions?
352Likes
