Team Associated B6.1 & B6.1D thread >
Like Tree1089Likes
    Hide Wikipost
Old 03-24-2020, 06:21 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Team Associated B6.1 & B6.1D thread
Last edit by: Kraig
Welcome to the B6.1 and B6.1D Wiki page.
Features:
Easy-access gear differential
Differential height adjustment with 0, 1, 2, and 3mm inserts included
New slipper assembly for better weight balance and shock clearance
3-gear Laydown Stealth(r) transmission for lower and forward CG
Heavy-duty V2 routed graphite front shock tower with tower guard
Heavy-duty V2 routed graphite rear tower, standard height
Heavy-duty V2 rear axle with 67mm bones
V2 springs for a more reactive and nimble feel
Innovative rear arm with molded inserts for ultra-fine lower shock mount adjustment
Molded spur gear guard to help protect body from damage
Front and rear anti-roll bars limit chassis roll for increased corner speed
Battery strap allows the use of optional turnbuckle-based braces
Machined pistons included for better fit and smoother operation
Aluminum rear clamping hex and front axle with laser etching
Rear hubs feature large bearings and the easy-insert system to adjust camber link position and rear axle height
One-piece shock bushing to make assembly easier
Aluminum C and D arm mounts included for large range of anti-squat and toe adjustment
Lightweight aluminum top shaft
Factory Team upgraded ball bearing kit included (now oiled instead of greased for less drag)
JConcepts(r) B6 clear body and wing included
Steel chassis weight
Shortened, 7075 aluminum chassis
Features:
Easy-access ball differential
3-gear Lay Back Stealth(r) transmission for lower and rearward CG
Heavy-duty V2 routed graphite rear tower, long
+1 steering block arms optimize feel on dirt tracks
Setup Sheets and other documentation
Setup sheets for both cars:
Piston Drills:
Aftermarket Upgrades:
Parts List:
Reference Guides (courtesy of Ray Munday and Roger M.):
Print Wikipost
Old 03-01-2019, 04:40 PM
  #2491
socalcloin's Avatar
Ah cool that makes sense.. the B6.1d was the first RC I built and raced since the RC10GT back in 2000. So any of those types of things I missed. I was out of the loop on top of being rather dense haha.
I had a TLR 4.0T but I got it used and ran it stock before I switched to the B6.1d
socalcloin is offline
Old 03-02-2019, 12:45 PM
  #2492
dr_hfuhuhurr's Avatar
Trader Rating: 95 (100%+)
For the shocks, moving from 1.8 with 35wt oil in the rear shocks, moving to 1.7 what would be an equivalent weight oil to use? Or asked in a different way to ask, If I went from 1.8 to 1.7 pistons in the rear, keeping the same oil. 1.7 would feel like 1.8 with what oil?
dr_hfuhuhurr is offline
Old 03-02-2019, 01:53 PM
  #2493
The smaller hole piston will provide more pack on landing and respond quicker to driver input. You trade off stability for better landing characteristics.
As a rule of thumb I've heard every .1 change in piston hole size is similar to a 5wt oil change. So 35wt with a 1.8 will be close to 30wt with a 1.7
trf211 is offline
Old 03-02-2019, 02:11 PM
  #2494
Thanks for the info. Since I'm racing turf without many large jumps I'm probably better off with the 1.8?
Old 03-02-2019, 02:52 PM
  #2495
To be honest I don't race turf so can't give you a clear answer on that. Try asking your tracks fast drivers if they have tried pistons besides the 1.8 and what you can expect at your track.
trf211 is offline
Old 03-03-2019, 12:10 AM
  #2496
Hello all,
Without having to read 167 pages -- can someone recommend a thick (i.e. sturdy and less breakable) aftermarket rear wing for the B6.1D, please?
Thanks in advance!
Yess is offline
Old 03-03-2019, 05:49 AM
  #2497
Cappy's Avatar
Trader Rating: 16 (100%+)
Leadfinger makes a real sturdy wing
Cappy is offline
Old 03-03-2019, 05:54 AM
  #2498
Trader Rating: 19 (100%+)
speed101 is offline
Old 03-03-2019, 05:57 AM
  #2499
Did associated fix there Direct Drive problem
speed101 is offline
Old 03-03-2019, 07:28 AM
  #2500
If by that you mean did they widen the gear on the input shaft? Then, no, they haven’t unless you get it from a Factory Lite kit.
I was skeptical, but I bought one anyways and have been running it in 17.5 indoor on carpet with no problems. For reference, I’m referring to Associated part 91800.
fastev is offline
Old 03-03-2019, 09:24 AM
  #2501
What low profile Reedy servo do you guys recommend?
Also, what shorty battery size? Weight mainly do you guys recommend?
thanks!
Ben Burtle is offline
Old 03-03-2019, 11:32 AM
  #2502
thank you
speed101 is offline
Old 03-03-2019, 12:19 PM
  #2503
thanks!
I've been using RS0806 and while it is a quality servo, the torque is too low, would recommend a RT1408 or RS1306 if you are choosing from reedy LP servos.
Protek 4900. 200g shorty is pretty standard.
trf211 is offline
Old 03-03-2019, 12:44 PM
  #2504
Alright... thank you, I appreciate the input.
Old 03-03-2019, 05:52 PM
  #2505
Trader Rating: 15 (100%+)
No problems for me running the direct drive. Ran it on dirt with cut transmission gears with no issues. Switched my car over to carpet and idler stripped instantly. Put the full width idler back in and no issues on carpet with the direct drive.
mx836 is offline
