Team Associated B6.1 & B6.1D thread
#3811
What is needed to convert the B6.1d to b6.1 carpet racer?
#3812
Not much, springs & oils, gear diff, electronics and servo weight (I don't think the 6.1D came with weights) and then maybe anti roll bars - I raced a 6.4 on carpet and liked it without anti roll bars. The axle height on the C was 3/0 but with the D you can run 2 up so quite close.
#3813
#3814
#3815
Thank you Pistol.
#3816
Thanks... Yea I have a 6.1
The shop I think has a 6.3 that I was looking at getting bnb to support the local mom and pop shop but want to be sure I can keep the b6.1(interchangeable parts as needed... spare parts) up and running for a friend to come out with me and I can let them drive that. Looking at getting some friends into the hobby so I won't be lonely lol.
#3817
If I remember correctly, the 6.1D used the longer 31mm rear body shocks, where the carpet car used 27.5mm bodies, but both would have used 27.5mm shafts ... different rear shock towers ... also the steering block was different I think
Here you go, found this tucked away in my files:
Red RC » Team Associated B6.1 & B6.1D Team Kit 2WD buggies
#3818
Just something to be aware of with the B6 Builders Kit ... the shock package is unique to this kit, 24mm bodies with 21mm shafts ... unlike most of the other AE shock bodies which measure pretty true to their listing size the 24mm bodies actually measure closer to 25mm if I remember correctly ...
#3819
Thank you guys.
#3820
Anyone have a standup 3 gear motor plate they want to sell. I have a bent one and need a replacement. Part number was ASC91794. Shoot me a pm if so please.
