Like Tree55Likes
RC10B4/T4 Forum
Old 10-15-2008, 10:28 AM
  #5746
Syber Serulean's Avatar
Trader Rating: 28 (100%+)
are the t3/b3 slipper plates smaller than the b4/t4's? I wonder...if they are a direct fit onto the b4, the tootsie roll setup can be used with even smaller spurs using the supposedly smaller slipper plates, right?
Syber Serulean is offline
Old 10-15-2008, 10:40 AM
  #5747
What up?'s Avatar
Trader Rating: 14 (100%+)
Chris you going to peg on Saturday? Dude by the time you put in all the work of putting this thing together you might as well get the turbo hub and redo your diff.
What up? is offline
Old 10-15-2008, 10:42 AM
  #5748
ill be there if my girlfriend has to work, shes not sure if shes gonna get called in or not yet.
and lol to your comments
im about to order a 72t spur and a 69t spur and slipper pegs. They are tc3 spurs and lucky me...i own a tc3 haha. So if they dont work, ill end up using the 69 for 17.5 in tc3 eventually.
the AE spurs and Kimbrough spurs are the same right? The place im ordering from has the kim 69 but not the kim 72, only the AE 72...
these should also prove useful, josh.
http://www.rcboca.com/product.php?pr...&cat=36&page=1
Old 10-15-2008, 10:53 AM
  #5749
What up?'s Avatar
Cool. I should be there too.
I dont know what 17.5 your running but I am currently running 65/33 and planning on going to a 34 pinion with my novak and the motor is coming off the track after each race temping at 115 to 120 plenty of bottom end and very quick down the straight.
I know Murffdogs 17.5 at the nats where running a 72 spur and they were very quick but it depends on the motor from what I am finding out.
What up? is offline
Old 10-15-2008, 09:49 PM
  #5750
ddd228's Avatar
Trader Rating: 24 (100%+)
Default B-4 foamies.
Originally Posted by DerekL
dont know that you can get foamies, unless you make em.
Try to make some out of the Jaco's for the T-4. Talk to some Associated sedan racers also.Check out some foams for a 10L,also.The rears are a bolt on? Been too long since my 10-L is gone. Foams for my T-4 make it accelerate very quickly-I still have some from when I raced on the Rain City carpet track.
ddd228 is offline
Old 10-16-2008, 04:43 PM
  #5751
astroboy403's Avatar
well looks like im getting a T4. i drove one of my friends and had a blast! just one question, what gearing for a 13.5, thank you.
astroboy403 is offline
Old 10-16-2008, 07:25 PM
  #5752
GMS_Racing's Avatar
Trader Rating: 65 (100%+)
17/87 works for me
GMS_Racing is offline
Old 10-16-2008, 07:32 PM
  #5753
LOSI123's Avatar
Trader Rating: 63 (100%+)
I could not find a B3 thread,
so
Does any here know if the b4 rims and tyres will fit a B3?
Also can the b3 diff and slipper handle fast motors like say a 5.5 or 6.5turn brushless?
any help would be good
thanks
LOSI123 is offline
Old 10-16-2008, 07:47 PM
  #5754
Originally Posted by GMS_Racing
17/87 works for me
You use this gearing for a 13.5 brushless? Sounds like a gearing i would run if i was using a 13t brushed motor.
Tater salad is offline
Old 10-16-2008, 07:50 PM
  #5755
so
thanks
The rims should be the same
The diffs should last, i would recommend starting fresh with a diff rebuild kit and some carbide balls, break in the diff., set your slipper and it should stay butter for a while.
Old 10-16-2008, 08:17 PM
  #5756
Davidka's Avatar
Trader Rating: 86 (100%+)
so
thanks
The B3 rear rim is a very different offset. If you put them on a B4 the rear width will be VERY wide.
Davidka is offline
Old 10-16-2008, 10:06 PM
  #5757
lbckevin's Avatar
Trader Rating: 107 (99%+)
Hey Tyler...
At OCRC I run 26/78 for a 13.5 Novak motor.
lbckevin is offline
Old 10-17-2008, 09:49 AM
  #5758
Talking
Any advantage of using an inline axle? Anybody using it for racing? Ty.
longcaceres is offline
Old 10-17-2008, 10:15 AM
  #5759
d4man's Avatar
Never tried it. Supposedly, changing to the inline steering blocks (9577) and axles (7459) will give the car an overall aggressive feeling. Steering entering and exiting corners is increased but straight line stability is reduced.
d4man is offline
Old 10-17-2008, 10:35 AM
  #5760
What up?'s Avatar
Alot of the guys that are running the J82 kit like running the inline axles for better on power steering.
What up? is offline
