RC10B4/T4 Forum
#5596
I know other people are going to bash this or say its not the way to go but for $129 you can get a castle creations sidewinder with a 5700 motor, spend an extra $20 an get the castle link so you can program it on your pc. Its an awesome combo, and will move the t4 with no problems. Its reliable and their customer service is second to none.
#5597
i didnt check all 200 posts but have any of you guys swapped from losi trucks to asso truck,if so do you feel you made the right decision,did it help your driving,or just something new,been going back and forth on switching just wanted to get sum outside input,thanks in advance....
#5599
#5600
#5602
I've been happy with this setup. There's only like 2-3 things that are the same as stock setup. It's similar to the Trackside setup with slight changes.
Indoor, super high bite--clay, 6000mah Lipo---no weight added. Truck comes in at 1860grams on the scales. Yes, even with lipo it's way over weight. The shell alone adds 100g. The shell is the stock AE body.
#5603
#5605
your best bet esc/motor wise. would be a mamba and 5700 if your gonna be racing mod.. the esc is damn near indesctructable and is about 1000 times more adjustable. dont worry about the stutter. they preety much have it worked out. i roll my b4 backwards and get on the throttle slowly and it comes to a stop smoothly and accelerates forward smoothly. on the mamba you can set everything even throttle curves.
#5606
wierd about the shocks though so you didnt like the ass shocks??
do you run the gas truck front end-heavy duy or still stock??
#5607
MUNN thanks for the info..just kinda burned out had losi forever,thats why i havent switched yet i have so many ext chassis,parts,wheels etc,now they will be no good to me..
The Assoc. shocks are horrible to work if you are coming from a Losi car, or even a Kyosho car. You have to disassemble them entirely in order to change o-rings. That was not fun.
#5608
Try this one out ..
Rebuild your Ae shocks , make sure the shaft & supension pins are not bent.
Then take your ride over to your bud`s Losi or kyosho and push the their chassis down.
then
You can & will feel just how much smoother the Ae is compared to those other`s rides...
then
#5609
Try this one out ..
then
then
I have 2 kyosho's and 2 ae's and you are sadly wrong the kyosho shocks are the smoothest between the two different brands especially when using the Kyosho X-rings.
Losi i couldn't tell ya don't have any.
#5610
next time put both rides side by side & compare , I have ..
The ae is a lot smoother...
