RC10B4/T4 Forum
#4846
Trader Rating: 18 (100%+)
A question for the assembled T4 / B4 experts here...
I just received two pairs of threaded rear shock bodies and two pairs of threaded front shock bodies I purchased on e-Bay. They are supposed to be "hard coated" and one pair of each certainly is. The other pair of each looks like plain old dull aluminum. Regardless of color they DO have the same part number on the header tags. The header tag on the "plain" looking fronts says "anodized" but the header card on the rears just says "threaded shock" with no reference to anodizing.
The folks I bought from supposedly closed a hobby shop. Their reply was that it was a running change from when production was moved to China, that they are all hard coated.
Is this the case or is someone blowing smoke up my skirt?
#4848
Might be too much IMO. I have the 6.5 on my B44 and it is VERY fast. I saw a guy with a 6.5 and the T4 was quite a handful. Fast, but quite a handful.
#4853
Switch to green springs on the rear, lower you rear ride height & most important loosen your slipper....
#4856
#4857
dunno which cooling fans are good. broke a few myself. I just ordered 4 x 3racing ones for $15 shipped. hope 3racing's quality as good as it looks
#4858
Try these fans out. I run these and they work really good, I just ordered 2 more for my other cars.
http://www.rctech.net/forum/showthre...hlight=GTB+fan
#4859
Front:
35wt oil
piston 1
0 limiters
middle hole on tower
outer hole on arms
front arms level
Rear:
25wt oil
piston 1
1 limiter
inner hole on tower
inner hole on arms
CVD's level
Shocks are just the first thing your going to want to change when running light, the rest of you setup isn't "as" important as shocks, but every thing works in conjunction.
#4860
