RC10B4/T4 Forum
#4696
I've got 3/4 oz in the front and alot more than the standard 1.5 oz in the rear (more like 2.5-3oz, Ihaven't added it up) all due to changing to lipos. I know when there is too much on the front but w/ what I've added to the rear it's nice and balanced. I also have it balanced well from left to right. I'm running the orion 3200 (200grams) and was running Ib4200s(450grams!!) so I dropped 250grams. some are adding exactly all the weight they dropped when going to lipos but I feel you don't get all the advantages of the lipo packs if you do. With the lighter pack I really had to loosen up the car to get the weight moving around.
Link to my setup sheet for my T4. ..by B4 is similar but not posted. I put in there where and how much lead I've added. I'm also running an alumium motor guard that adds 1/4 oz over the stock/plastic guard.
http://www.nashrcracer.com/coppermin...album=26&pos=0
#4699
a 20t or a 21t just to start with
#4700
#4701
Andrew, Johnny- i made a couple of changes over the past 2 weeks:
Front:
Brown springs, #1 Pistons 35 weight AE Oil.(shock ends unscrewed 2 turns)
Inside on tower, outside on arm.
2-B camber link.(outside tower, outside hub)
25 degree caster blocks.
Spindle in the middle of washers.
One washer under spindle.
-1 degree camber.
RH-Arms Level.
Team Losi 2wd Taper Fronts.(stock foam)
Rear:
Silver springs, #2 Pistons 25 weight AE Oil with one limiter.
Inside on both tower and arm.
Inside on u-brace, middle on hub.1-B? (U-brace grinded down level where ballstud goes, no washers)
Middle wheelbase.
1 degree antisquat.
-1 degree camber
RH-Bones slightly above level.
Team Losi BK-Bars.(bomb 1)
Other notes: Traction compound: Motor Spray. Keep o-rings fresh in shocks, 1 oz. weight in rear in front of tranny. LRP Sphere, Team Orion 10.5 w/ 4800 Platinum Li-Po with 5oz. lead weight under lipo. Pro-line Cav. Edition Crowd Pleazer w/ 5 in. Pro-line wing.
Front:
-1 degree camber.
RH-Arms Level.
Rear:
Middle wheelbase.
1 degree antisquat.
-1 degree camber
#4704
Shock bushing's? No I think everyone run's the stock plastic one's at our track.
#4706
For the rear you need to get the ones labeled as tc4. They are a bit shorter. Buy a bag of each and you got enough for the truck and buggy.
#4708
I went back to using plastic bushings. They are much cheaper and faster to replace than the aluminum ones.
#4709
Front:
-1 degree camber.
RH-Arms Level.
Rear:
Middle wheelbase.
1 degree antisquat.
-1 degree camber
Front:
-1 degree camber.
RH-Arms Level.
Rear:
Middle wheelbase.
1 degree antisquat.
-1 degree camber
Thanks Mertz. I'll try out your new setup this weekend.
#4710
Ran my T4 for the first time last night and the first time ever with Lipos and BL. Unfotunately it was a load!. What are you guys doing that are running the lipos and not adding all of the weight back doing to compensate. It was just way to loose, both on and off throttle. It is basically the same setup as i see everyone else running with the exception of using the GT2 ront end. I think i remember seeing that the shock tower has a lower inner camber link mounting point. Is that going to give more or less sterring?
