RC10B4/T4 Forum
#3946
Thanks Jim, I have always really liked JConcepts stuff, although my last experience with them left me a bit sour, and i as only wish i had your paint skills. One question for you guys running BL and Lipo. How much weight are you adding? I just weighed mine and i am only 1 oz. underweight. I did put the plastic chassis on and the GT2 front end so i am guessing that is where some of the weight is coming from but i really expected it to be a lot further under than that. Or are you guys quite a bit above the 60 oz minimum?
#3947
-If you got you of the new kits(black box), the chassis should be the plastic one.
- The new kits have running change. The shock bodies(coatings) are being done by a different company. I'm not sure what car/truck that body relates to, but if there is problem with any of your kits, please call AE and explain. In MOST cases(if its related to quality), the problem will be handled. AE tries to make sure everyone is happy with thier purchase.
Are you sure that the new kits have plastic chassis?
What do you mean by "running change"? Are the shock shafts still unobtainium or are they the "gold" ones.
I'm thinking of buying a new kit.... It would be great if the new ones came with plastic chassis.
Thanks.
#3948
My GTB fits under fine without the fan, but I use a scoopless body. They have more clearance than the scooped version. (the scooped version is the one that comes with the kit).
I mount a smaller fan on the chassis with shoe-goo facing the esc.
What max-amps pack do you run? Were you getting through a whole day's racing on the one pack?
Cheers buddy,
W.
#3949
Yea i pushed the aluminum piece in the right side but for some reason 3 of the shock ends split. I love AE products i just found this to be weird.
#3950
Had a big problem today blew out rear shocks 2 times this is a new FTT4 checked all plastic shock pieces and o rings no tears and all was still in shock . replaced all inside parts twice and blew out 1 in the main. Made sure no air in shocks and they were not overfilled. I have been running Assoc. products forever and never had this problems. Any ideas maybe shock bodies? I checked all shafts straight and smooth.
I ended up getting some old shock bodies off a friend and they're fine....
BUT, a friend of mine bought his FTB4 a week after me, and he's beginig to develop the same problems I was having in his rear shocks as well....I think there is some kind of a machining problem in these new kits...
#3951
Hey Mr Mellow,
Thanks.
Thanks.
#3952
Awwww, thanks Jerrum
I saw in one of the posts that you ran your Orion til cut off. How long do you think you were running for? I'm keen to get some lipo-suction.
Have you bee practicing over the holidays? You cheeky little brat!!! I think I'm gonna get another B4 and do some mod class as well... maybe just use Yael's when she doesn't come out to race.
#3953
No practice over the holidays for me I think you might beat me next meet...for once
I ran that Orion for about 47 mins until it cut off, which was 6.8v for some reason. But after about 25-30 mins my lap times started dropping noticebly without timing gear.
By the way I was thinking about getting a Novak 7.5 light motor to try mod, I think I still will but I enjoy the close racing in stock.
#3954
I'll be strapping in my 7.5 for mod racing too. Don't know how well I'll do in mod though, coz I can barely wheel the B44 around at that speed
#3956
I read some where people are running 87/23 for 10.5. I cant get the motor back far enough to have a descent gear mesh. Are you guys modding the plate at all to do that or do i need to get a 81 or 84 tooth spur. i have not been to the track with it yet so i have been running it around the house full throttle and through the grass trying to get the temps up. I really think you could take the Peak/Orion BL down close to 9.0 to 1 and be ok.
#3957
I used the DS1015 in a 1/8th Truggy; never had a problem with it and it had more than ample torque and speed. For the B4 the DS1313 should work well.
#3958
I got new shock bodies today will see if this was the problem. I also put in new plastic parts hope this works. I will call assoc to see if they can help.
#3960
