RC10B4/T4 Forum
#3346
Well, it's time to tear my truck completely down. Haven't done a tear down on it yet. I've abused it on the track. We recently started running mod and it really took it's toll. My outdrives are slotted and the CVD bone ends are over half way cut through. Plus the diff was really bad through the night. Also I had two shocks that need rebuilt. So it's time to go through it a redo everything. The lower shock ends need replaced too. They are sloppy. So new outdrives, diff, shock seals, pistons, shafts, rod ends, bearings, CVDs, hinge pins, ballcups, and any bent turnbuckles. I'm gonna price all this and see how it compares to a new truck. Mine is seriously hammered. Of course, I bought it used back in February 07' so it didn't have a fair start from the beginning. It's been awesome though.
#3347
Yup probably cheaper to buy a new kit! lol
#3349
OK. i was going through the manual making the parts list and I noticed in the diff section they say to apply the steath lube to the diff out drives but not both sides of the diff ring. I have always applied the lube to both sides of the diff rings. Is this wrong/bad? I don't really see a problem other than maybe the diff rings won't apply the energy correctly. Cause when one ring spins, it spins the carbide balls which in turn spin the other diff ring the opposite direction. Since the carbide balls get the lube applied, will the extra film of lube on both sides of the diff ring be too much lube? IDK. Let me know what you people think.
Thanx
Thanx
#3350
Ok. $65 is not bad for the amount of race time this truck has had. I would like to upgrade to the FT parts but DAMN!!!!, that would double the price. OUCH! Seriously--$118 for my list plus the FT upgrades. I was surprised to find the alum. turnbuckles are triple the price of the steel ones. But I race every weekend Thurs-Sat/sometimes Sun. too. For the Team kit parts to hold up like they have is awesome to me. I don't see the need to upgrade to the FT stuff. But that's my own opinion. I have really abused this truck too. I'm really pleased to see that I don't need a new truck. LOL.
#3351
Heya all have a quick little problem with my T-4 wondering if anyone ever had the same problem and what was the cause. I was racing my T-4 and I kept spinning out. I thought that maybe I was giving it too much throttle and was not getting any traction. When I took off the rear wheels after the heat I discovered that one of the rear wheels was not lined up properly and wound up getting stripped out. Thinking this was the problem I replaced the rear wheels. Well as soon as I put some throttle on sure enough the same thing. So it was not the tires at all since I was running what everyone else was. Checked my diff and it seemed fine. smooth working like should. My best guess is that the problem is still with the diff, maybe too loose? I tried to dial down both steering and throttle expodential did not seem to make much of a difference. The truck seemed to run fine on the straights but had problems going in and out of a sharp turn. Maybe I am being a noob but I don't think it is my driving as the last time I had the truck out at the track it worked fine. Anyone with more experience with the T-4/B-4 have this problem? Thanks Gene
you running cvds or dogbones? ...I've had a cvd pin come sorta out and had a similar sympton as you... check cvd pins/axles out if you are running cvds..
oh, also if you've taken out any of the limiters in the rear shocks the dogbone axle maybe rubbing the a-arm....check the clearance
#3352
#3353
too much camber can cause the axles to rub the arms also...forgot to mention that part. You could have this spin problem if your camber if not even on bothsides... One tire is getting more traction...but you may not notice this until you get into some loose stuff. Check your camber links for bends or bent ball cups. I think I'm running 1-1.5 degress of camber now...not sure I kinda retired the truck and just running buggy on the dirt and TC on the rug. ..my TC4 needed some hobby love, so I raped the brushless out of the truck.
I've had your problem w/ my truck but my problem was my line/the track. the turn coming onto our big straight has some loose dirt and sometimes on the gas one tire would spin up and throw/spin me straight into the wall... my fix was getting my camber evend and just a better line or better throttle control when I did run wide....
Have you taken the pinion off and ensured that everything is free rolling while moving the rear arms (from full cpmpressed to normal ride height to fully extended)? nothing should be draggin/rubbin.
#3354
Hey, i had that problem a few different times, Once was an outdrive bearing and the other time it was the inside rear hub bearing. The hub one would only bind at slight angled pressure from the cvd's so it made me think my diff was to tight. Dan
#3356
Here's something I'm gonna try. I'm going to run the diff backwards. How soon will it back out? Minutes or a weekend? I'm waiting for new outdrives and CVDs and for the weekend I'd like to swap stuff to the other side and use the side of the bones and outdrives that aren't punished. Our track doesn't require braking so the bad side of the CVDs won't be used too much when run backwards. IDK. Just a thought.
#3358
air8, that is a myth that the orientation of the diff screw will prevent the diff from loosening or make it loosen.
I'll explain why, rather then just tell you it won't happen based on position.
The screw threads are right handed, that is, if it were true, lets say the nut is on the left side. If it will be loosened by the left tire spinning faster then the right.....
Turn the diff around and the bolt head is on the left, nut on the right, but the thread orientation is still right handed...so the left tire spinning faster then the right will loosen the bolt, rather then the nut.
Also, if this were true, the right tire spinning faster then the left would tighten the assembly, no matter how it is facing, since the right handed threads would be tightened, either by the nut, or bolt head.
Bolt head-\\\\\\\\\\\\-Nut
Nut-\\\\\\\\\\\\-bolt head
Left loosens and right tightens, no matter which is on either side.
If the bolt/diff adjustment changes, parts are wearing, the lock nut is worn and not locking, or the thrust assembly(which keeps this from happening in the first place) is in bad shape.
Hope this clears that up.
...Jim
W.E.D.
...Jim
W.E.D.
#3359
wow....very well explained, the only reason i put the diff in the same way as the manual as its easy to pop that ballcup off to be able to get the wrench i use to adjust the diff.
also i went to the local hardware shop, and got some metal plates, each one is about 1oz, i put 4 under the battery, leaving me nearly an oz (for ib4200 weight) to put where i want...but since im running brushless (weights 1.1 oz more then brushed from what i have read on these forums) i think i should still be fine, i had too much rear traction when i switched from brushed to brushless so i believe it.
see how it runs next time i race, if i don't like it ill just add an oz of weight on the battery strap. to either add more steering or rear traction
