Like Tree55Likes
RC10B4/T4 Forum
Old 07-17-2010, 11:02 PM
  #13096
Tech Legend
Wild Cherry's Avatar
Originally Posted by RC10B4_Mafco
are you referring to the upper or lower edge?
All depends how soft you wish to make ...
full ft insert on ft tire
Usually slice 3/16 off the insert first then contour the in & outside edges..
Wild Cherry is offline
Old 07-18-2010, 06:34 AM
  #13097
TNS Racing's Avatar
does the b4.1 kit come with all 3 rear hub degrees?
TNS Racing is offline
Old 07-18-2010, 07:15 PM
  #13098
Matt Trimmings's Avatar
Trader Rating: 170 (100%+)
It comes with a new rear toe block that allows you to adjust it at the arm mount instead of the hub. It comes with 0 degree rear hubs.
Matt Trimmings is offline
Old 07-18-2010, 09:06 PM
  #13099
Davidka's Avatar
Trader Rating: 86 (100%+)
Are the Losi hubs an acceptable way to adjust toe? Using blocks shortens wheelbase when adding toe.
Davidka is offline
Old 07-19-2010, 12:08 AM
  #13100
Jowers's Avatar
Any means of adding rear toe-in will decrease wheelbase... minutely..
Wheelbase can be adjusted however you like by shimming the rear hubs..
Jowers is offline
Old 07-19-2010, 02:15 AM
  #13101
If you are worried about adjusting the toe at the block causing a shorter wheelbase...only slightly, and you can make up for that with adjusting the hub. i would be more concerned about adding losi hubs as they arent designed for the car and you could end up messing with the rear width.
Old 07-19-2010, 02:57 AM
  #13102
RC10B4_Mafco's Avatar
Trader Rating: 15 (100%+)
does anyone know if the factory team B4.1 has the motor spaced so that it is central?
RC10B4_Mafco is offline
Old 07-19-2010, 03:34 AM
  #13103
No it doesnt, most of the newer brushless motors are being designed to not have that much hang out of the left side and therefore be closer to the centerline.
Old 07-19-2010, 05:16 AM
  #13104
Jmuck69's Avatar
Trader Rating: 14 (100%+)
I believe the press release indicates .5 degree hubs are included.
Jmuck69 is offline
Old 07-19-2010, 05:53 AM
  #13105
My mistake....kit comes with .5 degree hubs
Old 07-19-2010, 08:31 AM
  #13106
TNS Racing's Avatar
so did the original b4 come with 0 degree hubs? How does the new toe block effect handling now that its at the arm mount?
Old 07-20-2010, 08:50 AM
  #13107
ok so i just picked a ft t4 and ft b4 up in a trade for my ve8 roller. im wondering if somebody can give me some ideas on what to get for these cars. for example.....what degree caster blocks,aluminum shock caps, etc.
bbrace3m is offline
Old 07-20-2010, 09:01 AM
  #13108
Cameron Kellogg's Avatar
Trader Rating: 45 (100%+)
I run speed passion v3 motors and it only took a 1mm spacer to balance the weight of the motor on the trans.
Cameron Kellogg is offline
Old 07-20-2010, 09:10 AM
  #13109
TNS Racing's Avatar
id get the new v2 shocks for both cars, it makes rebuilding them so much easier. Also get the 30 degree caster blocks because ive found them to turn much more effectively on smaller tracks. new rear hubs with the toe blocks found on the new b4/t4.1 kits.
Old 07-20-2010, 09:17 AM
  #13110
Trader Rating: 125 (100%+)
How did you do this?
kwiksi is offline
