RC10B4/T4 Forum
Can you tell a difference between the new plastic and the old plastic towers for the b4? If so can someone maybe post a picture of the difference?
The new front is built up more where the ballstud sits.
The rear, where the webbing is for the wing mount screws is solid on the new tower as well as where the battery strap sits is half the thickness.
Here's pics of the new towers.
The rear is also set-up for lipos, correct?
Thanks ill see if I have the new ones.
also the tower is molded differently where the battery strap sits, its about 3mm taller for more clearance for lipos
shock towers
so the changes are only on the plastic towers and not the carbon ones?
RC Dude,
I noticed in pictures, that Ryan Cavalieri seems to be using Lunsford titanium screws in certain locations on the B4.1 and B44. Is this just a way to lower the CG or extra strength?
so are the t4 towers new too?
I believe the SC10/T4 tower has not been changed. But I will double check when I get into the office tomorrow
Correct
Ryan uses them mostly for the "Bling" factor and less weight.
Like above I don't believe it's been changed but I will double check.
Correct
I do not know if it has been mentioned, but I saw a picture on ebay and the t4.1 comes with the motor guard off of the sc10, with the bumper mount. are you still making the motor guard without this mount?
What's the difference in the new V2 slipper plates?
R/C Tech Elite Member
