RC10B4/T4 Forum
#4247
http://teamfusionracing.blogspot.com...lipo-lead.html
FT T4, LRP Sphere Comp 07, Novak 13.5 25-78 gearing, Orion 3600 Lipo, Airtronics 358 servo.
I am running Ryan Maifields Nationals 06 Set-up:
http://www.teamassociated.com/racerh..._Nats_2006.pdf
#4248
hi everyone!
One of my rear CVD got a bit bent so its vibrating at high speeds...might try to bent it back?
Dont know how this happened, is this possible torque did this (run locked slipper) because never really crashed heaviely
How good are the MIP shiny CVDs?? Think I saw them on Cavalieri B4/T4/BJ4?
thanks a bunch!!
thanks a bunch!!
#4249
hi everyone!
thanks a bunch!!
thanks a bunch!!
#4250
I melt the lead and pour it into the small triangle chassis tubs next to the servo... I bought some lead tire weights and they melt easy... And if you do it rite, they can pop rite out and you can make dierent sizes.. I like the weight towards the front, better streering feeling..
#4251
Thanks for all your help folks. I have another question. My friend just bought a MaxAmps Lipo battery and the black and red wires interfere with the battery strap. Can they put those wires off to the side so that I don't have to squish the battery strap on the wires.
#4252
I just ran a maxamps battery last weekend.. I cut the front of the battery strap off so it does not interfere with the wires. I also took some material off the top of the strap where it hooks into the rear so it wouldn't pinch the battery so much. Everything works nicely now.
#4253
Hmm, I didn't want to do that, although I have thought about that. I have the Factory Team Battery Strap and I run 1.5 spacers in the front and 1.5 in the rear. I heard MaxAmps will custom wire the battery, I just wanted someone to confirm this. If the wire came out to the left or right of the strap, I would be very very happy.
#4254
I don't think the Factory Team battery straps are going to be a rare collectible commodity anytime in the near future, just cut the thing off and be done with it. Takes you 2 minutes with a Dremel.
#4255
Registered User
hi everyone!
thanks a bunch!!
thanks a bunch!!
#4259
DONT use the MIP ones!! The Gold Coating wears off quickly!!
#4260
I have always thought that the shiny CVDs last a lot longer--the holes don't enlarge in the pin area as quickly. There is almost zero wear on my BJ4 Shinys after 4-5 months of use.
I am using gold nitride MIP rear shock shafts because that is what my local LHS had and I needed some as my stock gold rears got bent over time. I had heard the MIP bend easier, but so far so good after 2-3 weekends.
The "old" style ti-nitride Associated shafts are the best. They are very glossy and smooth with a hard coating--also they are a lighter shade of gold. The "new" style which I have on my black box B4 FT--aren't as good. They are a mch darker gold color and they are matte, not smooth--so they might add a bit of stiction to the shock action.
The "unobtanium" shafts--the gray ones are actually titanium carbonitride coated, which is a more durable coating than titanium nitride (gold). At least it is for drill bits and machine parts.
