RC10B4/T4 Forum
#4276
i have an associated top shaft for the hydradrive its made by teddys racing products from back in the day but i am pretty sure it will fit all losi slippers and also pretty sure all associated top shafts will work on any model 10t t2 t3 t4 as long as you use the right slipper for the shaft
#4277
any one know the part # for the front stell axles the ones that screw a screw into. since the alumoun ones break.
#4279
http://www3.towerhobbies.com/cgi-bin...&I=LXFDW9&P=OW I know these are aluminum but, is this what you are looking for? You probably need different steering blocks if they are.
#4280
Try these, http://www.lunsfordracing.com/mm5/me...e=CARS-ARC10B4
Titanium front shafts, these use stock steering blocks.
#4281
nope they are just like the ft one's but steel istead of alum
#4283
Well today I had my first casualty with the new truck. After two passes on my street the truck skid into the curb and snapped the rear hub in half. This will never happen again as alloy ones are on there way.
#4284
With the alloy ones, yes it is true that you will PROBABLY never snap one again, but keep in mind, that when you replace parts with aluminum parts, the forces in a crash are just the same. So although the aluminum part won't break but the plastic part that the aluminum part is connected to probably will.
#4285
Point taken thanks
#4286
I've had the aluminum hubs Racer's Edge makes on my T4 and love 'em. Very nice machining quality and they have their own setscrew to hold the hinge pin in (so you can ditch the little 2-56 button head in the control arm).
#4287
Anyone else using these ball cups? Do the AE & Losi studs fit and measure out the same diameter?
#4288
Here is where I originally saw them used
http://rctech.net/forum/showthread.php?t=206949
and on a B4 by the same guy, Good looking vehicles
http://rctech.net/forum/showthread.php?t=208605
and then I double checked if anyone used them here
http://www.rc10t4.com/tips.php
I am giving the extra rigid a shot for the color gray instead and it says for serious racers on some site haha i prob dont fall into that category, more of a hacker. After I break 5 bulkheads maybe I will go back to the regular ones.
#4289
Mamba Max and Aon 4800 Killer series motor. I also run this in my X-6 conversion and my TTech 10X. This is one killer set up for me in these cars. I also run the Core 5000 lipo or the 5000 and 6000 Max Amps lipos.
