Speed Passion Thread >
Like Tree4Likes
Old 12-23-2013 | 07:02 AM
  #4216
Problems with a brand new pro 1.1 / 8.5 combo. About 2 min into first use the car stopped working. Motor will only run if you roll the car slightly. Then it cogs very bad. I replaced sensor wire, battery pack and reset/ recalibrated esc. Any ideas? This was a part of a Xmas gift so I wanted it to run when opened.
Chriscamp is offline
Old 12-23-2013 | 07:19 AM
  #4217
The problem you're describing is very common with a bad solder connection on one of the 3 wires between the ESC and motor. Once you double check your soldered joints, then try rotating each of the bullets 90° to see if you have a bad bullet connector on one of the leads inside the endbell. If the problem goes away temporarily, then you may have a bad male bullet inside the motor.
billdelong is offline
Old 12-23-2013 | 08:34 AM
  #4218
IGNORE. Answered my own question.
Snafujg is offline
Old 12-23-2013 | 08:39 AM
  #4219
Originally Posted by Snafujg
Sorry if this has already been asked/answered, but the search function isn't working for me. I wanted to know if the old GT 2.0 ESC can be updated with this latest Stock V21 software? Or do I need to upgrade to a newer ESC, like one of the Reventon's?
No, sorry...it cannot. GT2 is discontinued and they are using the older generation software that is not compatible with REVENTON software.
Solara is offline
Old 12-23-2013 | 08:50 AM
  #4220
chillindrdude's Avatar
how do you know if you have an older GT2.0? mine has the carbon case and ano purple heatsink.
chillindrdude is offline
Old 12-23-2013 | 08:56 AM
  #4221
Originally Posted by See
Attended the Pay it Forward race at amain hobbies this weekend managed to pull off a 3rd place finish.The Reventon Pro with the new stock o v21 software was smooth as can be.
Good job!
Originally Posted by kyoshoracer77
I got a revention r /17.5 combo. How much motor will they hold up to??
I am putting this combo in my sons corr truck with no timing he's a new racer. He has a sc10 rtr.
I am looking to buy a tekno410 corr truck. What does speed passion have to run this truck??? I DONT WANT A TEKIN OR CASTLE!!!
You can run a low turn regular mod motor or try the new Speed Passion Blaze 4x4 SC line of motors.
http://www.redrc.net/2013/12/speed-p...-course-motor/
See what billdelong wrote. Did a sensorboard go bad after a hard crash? Is the cogging happening all the time? low/mid/full throttle cogging?
Nexus is offline
Old 12-23-2013 | 08:58 AM
  #4222
I'm not sure what you are asking, but what you describe sounds like a GT Pro 2.0.
Nexus is offline
Old 12-23-2013 | 09:06 AM
  #4223
if the car was over geared, the ESC could've burned up too, do you know if there is overheat protection built into the ESC?
I once burned up an ESC (not from SP) when trying to run Open Mod with a 3.5T motor, fried the ESC in less than 2 min... literally melted the solder on the wires to the PCB of the ESC... totally my fault because I had the car over geared. The ESC I was running was supposed to have over heat protection but it didn't work, sure was fun running the car like a ballistic rocket while it lasted, I stay away from 3.5T motors now
Old 12-23-2013 | 09:20 AM
  #4224
All Reventons have the option of turning on/off overheat and voltage protection. Most racers turn it off though.
Nexus is offline
Old 12-23-2013 | 11:24 AM
  #4225
I had it turned on. This was first time out with a new buggy on a brand new track. Just taking slow laps trying to get a feel for the car. The cogging is only at slow speeds, but as soon as you stop it will not start up again unless you push it. I called speed passion and got a RMA to send it back.
Old 12-23-2013 | 12:38 PM
  #4226
Guest
[QUOTE=Nexus;12837082]Good job!
But what speed control can I run with that motor??? Revention pro ???
kyoshoracer77 is offline
Old 12-23-2013 | 12:55 PM
  #4227
[QUOTE=kyoshoracer77;12837690]
Good job!
You can run these with the Reventon Pro ESC
Nexus is offline
Old 12-23-2013 | 01:17 PM
  #4228
Guest
[QUOTE=Nexus;12837719]
No sh1t????? I plan on running a tekno sct410 with a revention pro and a 4500-5700 kV on 2s LIPO?. I like that!!!!
Now what about tekno en48 on 4s ??? The silver arrow v2 with the 2100kv motor??? Is this right or do u know of something different???
Old 12-23-2013 | 01:21 PM
  #4229
[QUOTE=kyoshoracer77;12837779]
The Silver Arrow and the Blaze 2100KV is very popular with our ebuggy racers. Depending on the track size or and traction you might want to look at the 1800KV also.
Nexus is offline
Old 12-23-2013 | 07:46 PM
  #4230
Autocratic's Avatar
Ran the new Reventon Pro 1.1 EX speed controls today in practice. 2wd mod and 4wd buggy.
Both speed controls did well and actually run cooler than the 1.0 Pros. I can tell the 1.1 ESCs have a little more power and punch over the 1.0 ESCs as well. Had to adjust my throttle expo a little more to get the car settled.
As always, can't go wrong with black either. Good stuff.
Autocratic is offline
